Homemade CNC Plasma - hypertherm, Mesa, gear drives, nema 34.
1 year 8 months ago - 1 year 8 months ago #320402 by RNJFAB
So i have done the calculator, and fudged the numbers to get the voltage back around 0v
Confirm - 1/32 setting on board.
Confirm - Plasma is set to 20:1.
Confirm - torch starts and the light on the THCAD 10 flashes faster.
Last edit: 1 year 8 months ago by RNJFAB.
1 year 8 months ago #320405 by rodw
Well the THCAD data is in hal so you are nearly there
what have you got set for
Voltage scale and voltage offset here?
linuxcnc.org/docs/stable/html/plasma/qtp...lasma:parameters-tab
Maybe PCW can see something missing on the night shift...
The following user(s) said Thank You: RNJFAB
1 year 8 months ago #320406 by PCW
Yes, this can't be right:
setp hm2_7i96.0.encoder.00.scale -1
It also looks almost like the velocity is random numbers
which suggests a wiring error or 7I96 encoder input 'A' not
jumpered for differential mode.
1 year 8 months ago - 1 year 8 months ago #320408 by RNJFAB
Realised that T17 didn't have the input on the encoder set for arc ok, T18 does.
Double checked wiring, 99% sure it's all correct.
File Name: T18.hal
File Size:10.95 KB
File Name: T18.ini
File Size:5.35 KB
File Name: custom.hal
File Size:1.81 KB
1 year 8 months ago #320409 by rodw
Well, that looks right.
PCW, the encoder details seem correct as they have been listed in an earlier post
I don't think I can help further..
1 year 8 months ago #320410 by rodw
assuming the plasma firmware is installed and it is a 7i96, The encoder pins are on TB2 as follows
Time to create page: 0.079 seconds
