External Jogging
- tld70
10 Mar 2013 21:59 #31176
by tld70
External Jogging was created by tld70
Hello,
on my Machine I do Jogging with external Buttons.
I select the axis with 3 Buttons and do the Signals to halui.joint.xxx.select
and the + and - Buttons goes to halui.jog.selected.plus and halui.jog.selected.minus
the pin halui.joint.selected shows 0 with x axis, 1 with y axis and 2 with z axis.
When I select x and jog than moves x-axis
When I select y then y moves.
But when I select z then y moves also and not z ?????
The halui.joint.selected shows 2
What is wrong?
Does someone have a idea?
this works under 2.5 the fault I see after update to 2.6
Best regards
Thomas
What is wrong?
Best regards
Thomas
- BigJohnT
- Thank you received: 1176
10 Mar 2013 22:26 #31178
by BigJohnT
Replied by BigJohnT on topic External Jogging
We would need to see your hal file to guess... attach it to a post.
- tld70
10 Mar 2013 22:29 #31179
by tld70
Replied by tld70 on topic External Jogging
Hello John
here is my postGui.hal
- BigJohnT
11 Mar 2013 00:25 #31185
by BigJohnT
The hal file looks ok, will it jog correctly with the keyboard?
- tld70
11 Mar 2013 01:18 #31187
by tld70
With the Keyboard its OK
- BigJohnT
11 Mar 2013 03:45 #31191
by BigJohnT
I'm stumped... unless you maybe have two buttons pressed at the same time... dunno, everything looks good in your hal file. What happens when you comment out the Y axis jog enable, does Y still jog?
- tld70
12 Mar 2013 00:15 #31242
by tld70
Hello John,
I commendet it out, and the same problem,
X and X moves
Y and Y moves
Z and Y moves.
in the AXIS Screen the Axis Jogginmg is OK
Any Ideas?
Thomas
X and X moves
Y and Y moves
Z and Y moves.
Any Ideas?
Thomas
- BigJohnT
12 Mar 2013 00:22 #31243
by BigJohnT
Sounds like the external button is wired to the Y axis and not the Z axis. If the jog buttons in Axis work properly but the external buttons do not it shows that from LinuxCNC to the drives is correct.
- tld70
12 Mar 2013 00:31 #31244
by tld70
The wirin should be OK
I have 1 + button and 1 - Button,
I have 3 buttons to switch the AXIS ( X Y Z )
And the Signal halui.joint.xxx.is-selected shows the selectes Axis, only when 2 is selected Y moves
- BigJohnT
12 Mar 2013 05:53 #31267
by BigJohnT
Are you using any feature in master that you can't run 2.5?
Time to create page: 0.064 seconds
