External Jogging
- Thank you received: 4994
13 Mar 2013 03:26 #31295
Back to trying with the sim, I think.
Replied by andypugh on topic External Jogging
Thanks. Sadly that config is very complicated and needs exactly the right hardware and all your custom components.here is the ZIP File
- tld70
13 Mar 2013 03:37 #31296
by tld70
Replied by tld70 on topic External Jogging
I know.
Its a Machine with 3 Servos, A Spindle, 12 tools Basket toolchanger Partchanger.
Spend a lot time to get this machine to run
13 Mar 2013 04:02 #31297
I can tell.
Even testing the jog is tricky, as you seem to be jogging with the parport?
Is it screen-jogging that causes the problem, or parport jogging?
I can tell.
- tld70
13 Mar 2013 04:10 #31298
by tld70
I do not understand what you correctly mean?
excuse my bad english.
If I move the Axis by Screen in Axis all is OK
If I move the Axis by Keyboard ( Cursor up down left right and picture up down )
all is OK
Only with the buttons ( conected by Parallel port ) the Y Axis move instead the Z
all is OK
13 Mar 2013 04:54 #31299
The keyboard and HAL jog commands take a different path through the code.
Can you confirm that when you attempt to jog Z that the pins
halui.joint.0.select
halui.joint.1.select
halui.joint.2.select
and
halui.joint.0.is-selected
halui.joint.1.is-selected
halui.joint.2.is-selected
Show the expected values?
I am going to try a simple version, but it is quite likely that what I remove will be the critical bit..
all is OK
and
- tld70
13 Mar 2013 05:05 #31300
by tld70
I confirm
when I select halui.joint.2.select will be 1 when I press the Z Key.
after press the Key it is 0
all other halui.joint.X.select are 0
and than the halui.joint.2.is-selected is 1
all others halui.joint.1.is-selected is 0
and halui.joint.0.is-selected is 0
but Y is moving.
hope this helps
If nothing helps, we can do a vnc sesson
but Y is moving.
hope this helps
13 Mar 2013 05:14 #31301
Which axis.n.motor-position-cmd pins change value?
but Y is moving
13 Mar 2013 06:17 #31303
OK, I have managed to reproduce the problem.
I think this is good news for you.
I am now changing to 2.5 to check that it isn't a problem there.
- tld70
13 Mar 2013 15:42 #31313
by tld70
Hi Andy
that means you find the Problem?
13 Mar 2013 16:54 #31314
I have found that there definitely is a problem. I haven't found the solution yet.
It looks like Seb did a lot of hacking last night, and has located the commit that caused the issue, but we are still not sure why:
psha.org.ru/irc/%23emc-devel/2013-03-13.html
Might make interesting reading.
Time to create page: 0.137 seconds
