External Jogging
- Rick G
- Thank you received: 155
12 Mar 2013 13:27 #31274
by Rick G
Replied by Rick G on topic External Jogging
Hello,
So it worked O.K. in 2.5 but not in 2.6?
Have you used Hal watch, selected all the pins involved in jogging all the axis from the input to the output, while pressing the buttons to see where the signal is being dropped / crossed?
Rick G
Rick G
- tld70
12 Mar 2013 14:29 #31276
by tld70
Replied by tld70 on topic External Jogging
Hello John,
I will try to use ORIENT ( OK It is not working now but I work on it )
Hello Rick,
I 'm sure it works under 2.5 ( But I try in today or tomorrow again to be sure )
I have watched all pins, but I will do it again today or tomorrow.
Thomas
Hello Rick,
Thomas
- tld70
12 Mar 2013 21:40 #31283
by tld70
Hello John,
Hello Rick,
I'm right back from my Machine.
I installed 2.5.2 and commended out the ORIENT comp and signals.
Now the Jogging works correct.
Than I checked the signals I ues for Jogging, and they are switching like it should be.
There is a bug somewhere in 2.6 I think..
When I switch back to 2.6 the Jogging doesnt work correct
Any Ideas?
Best regards
Thomas
Hello Rick,
Any Ideas?
Best regards
Thomas
- BigJohnT
- Thank you received: 1176
12 Mar 2013 23:18 #31284
by BigJohnT
Replied by BigJohnT on topic External Jogging
Thomas,
If you don't use orient in 2.6 does it jog correctly?
- Thank you received: 4994
12 Mar 2013 23:42 #31285
Replied by andypugh on topic External Jogging
Has anyone tried that postgui file on a different machine? I can have a go tonight, but perhaps someone is in a position to try it sooner?
- tld70
12 Mar 2013 23:57 #31286
by tld70
Hi John,
i removed the Orient Comp and nothing changes.
Hi Andy,
hope you find something, I have no Idea
Thomas
Hi Andy,
Thomas
- BigJohnT
12 Mar 2013 23:59 #31287
by BigJohnT
Post your xml file and I'll try them on a sim.
- tld70
13 Mar 2013 00:43 #31289
by tld70
Here is the XML File
13 Mar 2013 02:38 #31291
Can you zip the whole config directory up and post it?
I tried, but there are just too many components I can't guess the identity of.Here is the XML File
- tld70
13 Mar 2013 03:06 #31293
by tld70
Hi Andy
here is the ZIP File
Best regards
Thomas
Best regards
Thomas
Time to create page: 0.078 seconds
