External Jogging
- Thank you received: 4994
13 Mar 2013 21:00 #31322
Replied by andypugh on topic External Jogging
Jepler has found the bug. It is there in 2.5 too, but for some reason doesn't show up.
There is a fix that has been pushed to the 2.5 branch, but not to 2.6/master yet. (I am not entirely clear why).
Are you running from a buildbot build, or a locally-compiled version?
- tld70
13 Mar 2013 21:07 #31324
by tld70
Replied by tld70 on topic External Jogging
This is perfect.
I run 2.6 from buildbot
13 Mar 2013 21:13 #31326
I would expect the fix to be in place in a couple of days, and then the next update should get it.
If you can't wait that long, then some more HAL logic would allow you to link the jog buttons to the individual axis jogs rather than selected jog.
The following user(s) said Thank You: tld70
- tld70
13 Mar 2013 21:35 - 13 Mar 2013 21:44 #31329
by tld70
Hi Andy
no problem, I can wait some days.
can you leave me a message when it is fixed?
Thank you and the Linuxcnc Staff
Best regards
Thomas
Best regards
Thomas
Last edit: 13 Mar 2013 21:44 by tld70. Reason: Spelling fault
- tld70
19 Mar 2013 22:22 #31600
by tld70
Hi Andy,
do you know when the Bug is fixed?
I have done a update today, but it is still present?
If you intrested about the CNC-Maschine it is under Machines Chiron FZ16
Thomas
Thomas
20 Mar 2013 04:03 #31620
If you wait until the buildbot finishes the current build then you should get the fix.
buildbot.linuxcnc.org/buildbot/waterfall
It should be fixed now. (4 hours ago)I have done a update today, but it is still present?
- tld70
22 Mar 2013 00:51 #31685
by tld70
Hi Andy
i have done a update today, and the jogging works perfect.
Thank you
Thomas
Thank you
Thomas
- tld70
09 May 2014 21:25 #46758
by tld70
Hi Andy,
today I doe a update to 2.7 newest version,
I think there is the problem again.
I only can move with X amd Y axis.
any ideas?
Best regards
Thomas
any ideas?
Best regards
Thomas
09 May 2014 21:47 #46760
None at all, but it is unlikely to be the same bug as last time.
any ideas?
- tld70
09 May 2014 23:14 #46765
by tld70
Hi Andy
sorry
I found a bad cable from the button to the input.
everythin OK
Best regards
Thomas
sorry
everythin OK
Best regards
Thomas
