New Trajectory Planner - Testers/programs wanted
- JZHA1985
12 years 4 months ago - 12 years 4 months ago #47928
by JZHA1985
Replied by JZHA1985 on topic New Trajectory Planner - Testers/programs wanted
Not to sound at all lazy but I looked around and Googled but couldn't find the builds.
I'm really wanting to try it out since all I ever do is 3d profiling and any increase of speed would be applauded. I can crank up the speed and acel all I want but better planning could really make it awesome.
Last edit: 12 years 4 months ago by JZHA1985.
- skunkworks
- Thank you received: 153
12 years 4 months ago #47938
by skunkworks
Replied by skunkworks on topic New Trajectory Planner - Testers/programs wanted
The new TP behavior is on by default in master. If you have no TP
settings in your [TRAJ] section - linuxcnc defaults to.....
ARC_BLEND_ENABLE = 1
ARC_BLEND_FALLBACK_ENABLE = 0
ARC_BLEND_OPTIMIZATION_DEPTH = 50
ARC_BLEND_GAP_CYCLES = 4
ARC_BLEND_RAMP_FREQ = 100
sam
sam
The following user(s) said Thank You: JZHA1985
- JZHA1985
12 years 4 months ago - 12 years 4 months ago #47948
by JZHA1985
I just need to move the computer from the work area to inside for internet access.
I'll build the master branch and report backskunkworks wrote: The new TP behavior is on by default in master. If you have no TP
sam
- JZHA1985
12 years 4 months ago - 12 years 4 months ago #47980
by JZHA1985
I tried building with git but it wasn't going very smoothly due to my lack of experience. So I started over with a stock (no linuxcnc) 10.04 install and tried buildbot for the master branch. But in spite of me updating everything (I added the correct repos) and so forth this error occurs since I don't know what I'm doing it seems...
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
linuxcnc: Depends: libmodbus5 but it is not installable
Depends: linux-image-2.6.32-122-rtai but it is not installable
Depends: rtai-modules-2.6.32-122-rtai but it is not installable
Recommends: hostmot2-firmware but it is not installable
E: Broken packages
cnc@cnc-desktop:~$
- ArcEye
- Thank you received: 240
12 years 4 months ago #47981
by ArcEye
Replied by ArcEye on topic New Trajectory Planner - Testers/programs wanted
You need to install from the Live CD, to get the realtime kernel.
Nothing will work unless you have one.
Then you can either build a RIP install from the git repo or install the buildbot package of the master
- JZHA1985
12 years 4 months ago - 12 years 4 months ago #47997
by JZHA1985
Wow!! I usually set G64p.0025 for all my work but even with .001 I had DOUBLE(a bit less but before the velocity was everywhere) the feedrate plus its almost constant velocity. So I'll be getting a much shorter cycle time.. No video yet as I decided to rip my old choppers drivers up so it will be a day or two before I get the G540 setup.
Time to create page: 0.164 seconds
