- Thank you received: 10
New Trajectory Planner - Testers/programs wanted
- rellenberg
As for the homing issue, I don't think I've seen any violations myself, but I haven't been specifically looking for them during homing. My simulation configs have the homing process cut short, because I got tired of waiting 5-10 seconds every time I loaded the GUI. Nothing that I've changed in this branch should directly affect homing, but it's always possible there are unintended consequences.
- Rick G
- Thank you received: 114
As a side note auto homing seems to ignore the acceleration settings on some moves in both cases.
That may not have been clear, I meant with the original TP and the new TP the results are the same.
I added another arc to the end, but did not see an improvement.
Rick G
- skunkworks
- Thank you received: 153
The homing should be exactly the same as they are simple moves (no blending...)
sam
- skunkworks
- DaBit
- Thank you received: 19
Can I switch TP behaviour between old/new while running a program by setting a HAL pin/parameter or so?
- skunkworks
DaBit wrote: I haven't done that much milling lately and then only simple, non-short-segment stuff, but so far I haven't noticed strange issues with the new TP. Where the old TP would do an audible slow down/accelerate on segment to segment boundaries the new TP just continues.
