TCP 5-axis kinematics
- 3D-Master
- Thank you received: 5
29 Jan 2019 21:34 #125208
by 3D-Master
Replied by 3D-Master on topic TCP 5-axis kinematics
Thanks for your reply,
the problem is not switching kinematics at all, the problem is that the axis have to be at zero (at least form my knowledge, might have to loook into J0-J5) to not trigger a following error. I was able to switch trivial and 5 axis kinematics with my beaglebone but the axis needed to be at zero and this is (at least for me) very disadvantageous because the Cam software might not always go back to ABC=0 before disabling TCP and also i want to write a subprogram to use a touch probe to calibrate the exact center of rotation. So if i use the normal coordinates (XYZABCUVW) i want to stay with them the whole program if you understand right.
thanks
thanks
- r.lol
07 Feb 2019 12:53 #125920
by r.lol
Replied by r.lol on topic TCP 5-axis kinematics
Hello,
Take a glance at switchKins branch also uploaded here is a video demonstrating switch between kinematics right within a NGC program irrespective of where currently machine is positioned.
Branch is also having required files:
inigcodewith which this was tested.
ini
switchKinsAxis_mm.iniG12-test.ngc
The following user(s) said Thank You: Hakan
- Hakan
- Thank you received: 454
07 Feb 2019 19:13 #125942
by Hakan
Replied by Hakan on topic TCP 5-axis kinematics
That is something that could be really useful! Great work.
- grandixximo
- Thank you received: 406
12 Feb 2019 10:07 #126258
by grandixximo
Replied by grandixximo on topic TCP 5-axis kinematics
I've tested your configuration, it's exactly what is needed, thank you!
Only one thing I noticed, before homing the machine it doesn't seem to be possible to move axis C, i haven't looked in depth in the ini or hal files, is this a problem due to kinematics or is it fixable by hal/ini?
If it's not possible to move C before homing it's a major drawback because you can't override limits and get out of them, you would have to change settings to be able to come out of limits.
Tomorrow I'll have a deeper look into the ini and Hal to see if I can fix it from there...
- grandixximo
13 Feb 2019 01:29 #126318
by grandixximo
I've looked and can't find anything wrong with the hal or ini file that would prevent C from moving before homing.
this is the error that pops up in the terminal when trying to move
Exception in Tkinter callback
File "/usr/lib/python2.7/lib-tk/Tkinter.py", line 1544, in __call__
return self.func(*args)
File "/usr/bin/axis", line 2562, in jog_plus
speed = get_jog_speed(a)
File "/usr/bin/axis", line 1761, in get_jog_speed
if joint_type[a] == 'LINEAR':
IndexError: list index out of range
- grandixximo
13 Feb 2019 08:47 - 13 Feb 2019 08:59 #126328
by grandixximo
I think i figured it out, it's because in the Kinematics B is skipped, so the Axis interface somehow before homing thinks C should be joint 5 (according to X=>J0,Y=>J1,Z=>J2,A=>J3,B=>J4.C=>J5), but joint 5 doesn't exist, the jog pins for joint 4 (which is axis C in your configuration) work fine, it's because the manual switch is not available by pressing shift+4, so the interface before homing is not sure which joint is which axis, it is a bug but not related to the switch, i think the same would happen in master with a similar configuration but without switch.
Last edit: 13 Feb 2019 08:59 by grandixximo.
- 3D-Master
18 Feb 2019 15:59 #126719
by 3D-Master
how do you tell linuxcnc where the center of rotation of ABC is? can you specify the values in the var file? that would be great because i could correct the center of rotation (with a calibration program) without possibly restarting the machine.
25 Feb 2019 10:43 #127096
You can't tell it, and to an extent it doesn't need to know.
It would be useful to be able to do this to get a more accurate graphical preview, but it has no effect on what the G-code does.
In theory it could also be used to convert angular moves into linear feed rates, but I am not sure if any controls actually do that. LinuxCNC doesn't.
Because of this it is better to use inverse-time feed rates when linear and rotary axes are used simultaneously. This needs to be done in the CAM system which _can_ be told where the actual centre of rotation is.
Part of the problem is that this issue simply isn't considered in standard G-code. One interesting solution might be to add a new G-code (G94.1 is available) that defines the rotary axis origin in the current coordinate system. I think that this would be rather beyond the scope of a remapped routine, however.
Replied by andypugh on topic TCP 5-axis kinematics
- Leon82
- Thank you received: 79
25 Feb 2019 10:56 #127097
by Leon82
Replied by Leon82 on topic TCP 5-axis kinematics
On fanuc if you are in g43.4 TCP it uses a standard feed rate. The actual is allover the place depending where on the rotary or trunion it is. Almost like constant surface footage.
Without this mode inverse time would be needed.
26 Feb 2019 22:35 #127206
That's interesting. So there is an established G-code for this?
<Google> studylib.net/doc/6993852/fanuc-5-axis-programming-codes
So, not exactly what I was hoping for.
Still, it is an interesting idea to simply create a new feed or tool-length G-code that does this calculation. G94.1 Xn Yn Zn... for example.
On fanuc if you are in g43.4 TCP it uses a standard feed rate. .
Time to create page: 0.135 seconds
