- Thank you received: 13
papagno-source wrote: Thanks for the reply.
Summing up.
If I have a table where the rotation center of B is perfectly in axis with the rotation center of C the value of X.offset is 0,
the z.offset value will be equal to the distance of the table surface (perfectly horizontal) and the rotation axis of B.
You’re right it would not, I was referring by mistake to an AC configuration.I wonder would a y.offset make sense?
X, Y and Z are the offsets from whatever position your LinuxCNC considers as zero machine coordinates and the center of rotation of your B axis assuming no offset from A to B. A to B offset is then set on X and Z offsets (corrected)While the values of x.rot.point and y.rot.point are the distance values between the zero ref position and the table center of the respective axes.
While the value of Z.rot.point, would it be the distance with respect to the position of z ref, of the spindle nose with respect to the table surface or to the rotation axis of B?
