TCP 5-axis kinematics
6 years 7 months ago #161977 by andypugh
Replied by andypugh on topic TCP 5-axis kinematics
papagno-source wrote: Correct?
Probably. At this point you know as much as me.
In addition to the manual page:
linuxcnc.org/docs/2.8/html/motion/5-axis-kinematics.html
You can probably get some info from the sample config HAL files: (Actually, in this case the settings are made in the INI file, which is unusual)
github.com/LinuxCNC/linuxcnc/blob/master...ng/xyzac-trt.ini#L32
Note that two of the offsets are set to standard values, and one is linked to the tool length.
6 years 6 months ago - 6 years 6 months ago #164591 by MDM3D
Replied by MDM3D on topic TCP 5-axis kinematics
Dgarrett/All, I have tried to add the foward and inverse kinematics for an AB configured machine with a rotary table A and a rotating Spindle B. How do you think I should go about coding for the fact that my X rotation point moves with the head. It does not have a fixed point like a AC or BC table/table configuration? Would it be as simple as like how the tool length offset is configured. I am starting to see the advantages of having the table table configurations with the motion control. I would just loose to much space on my configuration if I did table/table.
For instance if I replaced x_rot_point with something like pos.x which would be the current X pos? If I am thinking correctly Y and Z rotation points do not move on my machine. I don't think I can define the X rotation point as a changing number in the .ini file.
Last edit: 6 years 6 months ago by MDM3D.
6 years 5 months ago - 6 years 5 months ago #166429 by papagno-source
Hi stay test on real machine xyzbc-trt configuration.
On real machine when switch on TCP-xyzbc and move B axis with jog-pendand in 0.1 increment the axis Z vibration , i thing have
immediate accelleration , for reduce this i have impose fractional-acceleration in ini file on B axis at 0.1 value.
The actual max acceleration for alla axis is 500 value.
Whit 0.1 the fractional-accellarion value , now move good, not vibration.
But i have test in manual mode B+ or B- with tcp on and Z axis vibration.
I don't have test again in automatic, but thing can create some problem , not understand how can resolve this problem.
I don't understand with TCP on , if move B axis , Z axis move with B axis max accelleration value or Z max accelleration value ?
Or when use TCPon in normal operation automatic mode , the velocity are small and this problem not appare ?
Last edit: 6 years 5 months ago by papagno-source.
6 years 5 months ago #166523 by papagno-source
Hi. I have test in automatic cycle and work good with tcpon and tcp off.
Have modification logic the machine , when is manual and have tcp on , can move only with jog pendant and not in JOG move .
Is dangerous move machine in jog mode with tcp on.
The next step will ceck the geometry table.
6 years 5 months ago #169351 by papagno-source
Hi .
i have cecked the my geometry table BC type on 5 axis machine.
When rotate B 90° or B -90 and control linearity along Y axis , have 5/100 mm on 300 mm travel the y.
Now for adjust the geometry , i can move the meccanical feedback , but not is ideal .
Exist in KINEMATIC , the pin for correct in kinematic geometry problem the table respect X axis or Y axis or Z axis ?
I thing a value imposed on some pin , loated in KIN , for correct automatically position the X axis , when Y axis move , for cancel the
5/100 mm the geometry error proporzional at Y movement .
6 years 2 months ago - 6 years 2 months ago #178838 by SB
Replied by SB on topic TCP 5-axis kinematics
I tested your branch with me. That was exactly what I was looking for, thank you very much.
I was wondering if there is a possibility to turn the direction of rotation of the A-axis, if so in which file can I do this?
X/Y/Z/A/C
Last edit: 6 years 2 months ago by SB.
The following user(s) said Thank You: daidai
Time to create page: 0.142 seconds
