TCP 5-axis kinematics
5 years 3 months ago #214096 by andypugh
Replied by andypugh on topic TCP 5-axis kinematics
At a guess, Dewey has deleted dgarr/s_kins
This is probably because switchkins has been merged in to Master. So checkout master instead.
5 years 3 months ago #214158 by JackRay
Replied by JackRay on topic TCP 5-axis kinematics
Hello ,
Please excuse me, but I don't quite understand. I do not have a high enough level under linux. do you mean i need to run the line with "sudo"?
Thank you
5 years 3 months ago - 5 years 3 months ago #214162 by Aciera
Replied by Aciera on topic TCP 5-axis kinematics
You should install linuxcnc-master branch:
git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-master cd linuxcnc-master/src ./autogen.sh ./configure --with-realtime=uspace make && sudo make setuid cd .. source scripts/rip-environment linuxcnc
Last edit: 5 years 3 months ago by Aciera.
5 years 3 months ago #214177 by JackRay
Thank you for these informations ,
But i want to run xyzac-trt.ini and i have this message ...
jack@jack-linuxcnc:~/linuxcnc-master/configs/sim/axis/vismach/5axis/table-rotary-tilting$ linuxcnc xyzac-trt.ini
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/jack/linuxcnc-master/configs/sim/axis/vismach/5axis/table-rotary-tilting'
Machine configuration file is 'xyzac-trt.ini'
check_config: Unchecked: [KINS]KINEMATICS={xyzac-trt-kins sparm=identityfirst}
Starting LinuxCNC...
Found file(LIB): /home/jack/linuxcnc-master/lib/hallib/basic_sim.tcl
setup_kins: cmd=loadrt xyzac-trt-kins sparm=identityfirst
HAL: ERROR: version code mismatch
HAL_LIB: ERROR: could not init shared memory
hal_lib: rtapi_app_main: Invalid argument (-22)
Note: Using POSIX realtime
xyzac-trt-kins: dlopen: /usr/lib/linuxcnc/modules/xyzac-trt-kins.so: undefined symbol: hal_exit
msg=waitpid failed /usr/bin/rtapi_app xyzac-trt-kins
/usr/bin/rtapi_app exited without becoming ready
insmod for xyzac-trt-kins failed, returned -1
setup_kins: unknown [KINS]KINEMATICS=<{xyzac-trt-kins sparm=identityfirst}>
motmod: dlopen: /usr/lib/linuxcnc/modules/motmod.so: undefined symbol: hal_stop_threads
core_sim: loadrt motmod FAIL
     msg=waitpid failed /usr/bin/rtapi_app motmod
insmod for motmod failed, returned -1
LinuxCNC terminated with an error.  You can find more information in the log:
    /home/jack/linuxcnc_debug.txt
and
    /home/jack/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
thank
5 years 3 months ago #214184 by Aciera
Not sure about that but maybe close the terminal window and open a new terminal window then retry:
cd linuxcnc-master source scripts/rip-environment linuxcnc -l
5 years 3 months ago #214186 by JackRay
Linuxcnc launches fine, but I cannot run it with the "linuxcnc xyzac-trt.ini" configuration. I have an error like in my message
Time to create page: 0.123 seconds
