Hello Can someone explain it to me.
My goal is to install linuxcnc swtichking because I have designed a continuous 5 axis machine which works very well.
But if I change my PC I find it difficult to reinstall on this configuration. I am looking for all sources. Compline etc.
But according to the different distrubition the behavior of the installation is not the same.
I found a Xubutu distrubution with Linuxcn2.9pre already installed. I would simply like to add the swichking branch to make my machine work.
For everything to work with the congif machine, I have to install alongside linuxcnc, Linuxcnc-dev and now Linuxcnc-master.
I think I'm doing anything, but I don't know how to do otherwise.
In fact, I will want to start from a distribution like LinuxMint, Dabian, Unbutu ...
Install a real time, then install linuxcnc2.9Pre with the SwichKing.
This is my ultimate goal.
Or is there a distribution with everything integrated?
If you have solutions I am interested
Thank you for your help
