TCP 5-axis kinematics
5 years 3 months ago #214575 by JackRay
Replied by JackRay on topic TCP 5-axis kinematics
As I said above I have a Xubuntu version with linuxcnc 2.9pre which works very well and is stable; is it possible to simply add the "SwichKins" branch to do 5axis TCP with "xyzac-trt.ini" on this version?
5 years 3 months ago #214577 by JackRay
I just say that I have failed with the terminal
jack@jack:~$ sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
[sudo] Mot de passe de jack :
Executing: /tmp/apt-key-gpghome.BM7d7Ya14E/gpg.1.sh --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
gpg: échec de réception depuis le serveur de clefs : No name
jack@jack:~$ sudo apt-get install dirmngr
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
dirmngr est déjà la version la plus récente (2.2.12-1+deb10u1).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 122 non mis à jour.
jack@jack:~$ sudo apt-key adv --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E
Executing: /tmp/apt-key-gpghome.jHKNsl24Lc/gpg.1.sh --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E
Executing: /tmp/apt-key-gpghome.NHujYBZFIu/gpg.1.sh --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
5 years 3 months ago - 5 years 3 months ago #214578 by Aciera
Replied by Aciera on topic TCP 5-axis kinematics
Forget the "SwitchKins" branch it's been rolled into the current master (ie 2.9pre).
How did you get linuxcnc 2.9pre on that Xubuntu (ie deb install or rip install)?
I'm not familiar with Xubuntu but if it's a deb install you can try to add the repositories in the package manager ( or whatever it's called in Xubuntu) and see if you can update to current master.
If it's a rip install then you should have (most) of the dependencies installed and I would do a rip install again.
[edit]
Ok the key is not working for me either so that is not your fault. I'll see what I can find.
Last edit: 5 years 3 months ago by Aciera.
5 years 3 months ago #214579 by Aciera
Ok, skip adding the key and try to add the repositories in the synaptic manager.
5 years 3 months ago #214595 by JackRay
Thanks, I also have a Linux Mint version with built-in linuxcnc 2.8. Can I do something with it, or is it better to do with Xubuntu.
I give you the link to download Xubutu Linuxcnc 2.9Pre RT 5.29
www.machmaker.pl/1_5_pliki-do-pobrania-downloads.html
5 years 3 months ago - 5 years 3 months ago #214597 by Aciera
you can certainly try to add the repositories in the xubuntu and in linuxmint and then check if you get the packages in synaptic.
Doesn't break anything if it doesn't work.
[edit]
there is quite a collection of ISO there.
Time to create page: 0.181 seconds
