TCP 5-axis kinematics
5 years 3 months ago - 5 years 3 months ago #214706 by Aciera
Replied by Aciera on topic TCP 5-axis kinematics
Is this for Xubuntu or the official ISO?
which distribution did you use stretch or buster?
[edit]
last question is regarding what you wrote in the "Distribution" field when you added the repositories.
Last edit: 5 years 3 months ago by Aciera.
5 years 3 months ago #214713 by JackRay
Replied by JackRay on topic TCP 5-axis kinematics
1) I'm still on official debian version.
2) I used "stretch" as on the video "buster" doesn't seem to work ...
5 years 3 months ago #214716 by Aciera
For the official debian ISO you would want to use "buster". Worked for me after I added the key with the command
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com --recv-key EF1B07FEE0EE663E
In what way did it not seem to work for you?
5 years 3 months ago #214728 by JackRay
I did this, I tried, but he tells me that he cannot find the dependence "libboost-python1.62.0"
I did this, I tried, but he tells me he can not find the dependence.
Not easy anyway.
I will try to put my configuration Under Xubuntu linuxcnc 2.9pre. if I just have to copy my configs files, it will be easier. But I still think I will run into other problems ...
5 years 3 months ago #214732 by Aciera
Not easy anyway.
No, this should be a lot easier. I agree.
Have you removed the 'stretch'-repsitories you added before?
Maybe you could post a screenshot of your synaptic package manger window showing the repositories?
5 years 3 months ago - 5 years 3 months ago #214748 by JackRay
I am on Xunbutu where the Linuxcnc 2.9pre configuration is already installed.
I copy my configs files in the "Linuxcnc" folders
I then started linuxcnc as described, but it also doesn't work:image missing /media/kunena/emoticons/sad.png
Last edit: 5 years 3 months ago by JackRay.
Time to create page: 0.078 seconds
