TCP 5-axis kinematics
- JackRay
- Thank you received: 14
15 Jul 2021 11:56 #214850
by JackRay
Replied by JackRay on topic TCP 5-axis kinematics
- Thank you received: 2176
15 Jul 2021 12:04 #214852
Replied by Aciera on topic TCP 5-axis kinematics
That is the download link for the official linuxcnc ISO.
You can save the file into the Downloads folder and then write it to a USB stick using 'disk image writer' (for a linux machine) then you plug that into the computer you want to install linuxcnc on and boot from the usb stick you can then install linuxcnc 2.8 from the USB stick onto the harddrive.
- Thank you received: 7481
15 Jul 2021 12:17 #214857
If the question was "why this exactly", that is the latest build with some bugs removed and some features added in Debian.
Replied by tommylight on topic TCP 5-axis kinematics
Hello ,
Thank you , but what this exactly www.linuxcnc.org/iso/linuxcnc-2.8.2-buster.iso
The following user(s) said Thank You: JackRay
- JackRay
15 Jul 2021 12:26 #214858
by JackRay
Yes, I understand, but this version does not contain a switchable control?
- JackRay
15 Jul 2021 12:33 #214859
by JackRay
You said in the Forum :
The branch can be installed using a 'scratch' deb from the buildbot. See the instructions at
buildbot.linuxcnc.org/
The 'scratch'-debs can be found in the last section of the page sorted by distributions. They are built automatically by the buildbot and are available for a limited amount of time.i tried with synaptic, but it doesn't work ?? deb buildbot.linuxcnc.org/ $DIST scratch-sim
deb-src buildbot.linuxcnc.org/ $DIST scratch-simdeb buildbot.linuxcnc.org/ $DIST scratch-rt
deb-src buildbot.linuxcnc.org/ $DIST scratch-rt
15 Jul 2021 12:34 - 15 Jul 2021 12:35 #214860
No, for that you will need to update the 2.8.2 version it installs to current 2.9pre using the synaptic package manager.
Since this seems to have failed to work for you so far it might make sense to start with a fresh install of 2.8.2
Last edit: 15 Jul 2021 12:35 by Aciera.
- JackRay
15 Jul 2021 12:48 #214865
by JackRay
yes, I got there now I have version 2.9pre under Dabian 10.
I am now looking to install the switchkin branch with buildbot.
I just sent you a post
- REX299
- Visitor
15 Jul 2021 13:41 #214871
by REX299
Replied by REX299 on topic TCP 5-axis kinematics
I am also total new with Linux, just working with Linux for 3 days!
Now I success switch kinematics, now I will find out what I have to do to input axis offset.
- JackRay
15 Jul 2021 14:27 #214876
by JackRay
can you tell me how did you install the switchable kinematics?
Synaptic or by rip?
The offsets of the x, y axes must be in the center of your pivot axis, has value to enter your .ini from your original shots.
for the z value, you have to take the entire value of the axis - the height of your pivot center.
Synaptic or by rip?
- REX299
- Visitor
15 Jul 2021 15:25 #214887
by REX299
I just simple update from v2.8 to master 2.9pre, switch kinematics function already integrated in. I use Synaptic to update.
Time to create page: 0.381 seconds
