TCP 5-axis kinematics
- Thank you received: 2176
13 Jul 2021 08:42 - 13 Jul 2021 08:51 #214514
You can also use the mint distro.
[edit]
actually I'm not sure if the repo for the mint distro need to be different (stretch?)
[edit2]
Note that the use of the official ISO seems now the recomended method:
forum.linuxcnc.org/9-installing-linuxcnc...ation?start=0#137159
Replied by Aciera on topic TCP 5-axis kinematics
[edit]
[edit2]
Last edit: 13 Jul 2021 08:51 by Aciera.
- Thank you received: 7488
13 Jul 2021 11:15 #214540
Replied by tommylight on topic TCP 5-axis kinematics
Stretch is not built anymore, so buster is the one to use for Mint 19.x.
There is a quick and updated tutorial for Mint 19.x on the "installing LinuxCNC" section of the forum, it is pinned at the top so easy to find.
- JackRay
- Thank you received: 14
13 Jul 2021 12:41 #214568
by JackRay
Replied by JackRay on topic TCP 5-axis kinematics
I installed "Linuxcnc 2.8.0 buster.iso", nothing works, I can't even do an "Update my system". I would like to make a screenshot for you, I can't even find an application to paste my image ...
13 Jul 2021 12:53 - 13 Jul 2021 13:01 #214572
The ISO is fairly bare bones and light. But you should be able to connect to the internet, open the software manager and run linuxcnc.
[edit]
The changeover from LinuxMint might be a little bumpy but pretty much anything you might think your missing can be installed, you can even change the desktop manager to cinnamon as in LinuxMint.
I'm afraid this doesn't really tell me anything. (ie does it not boot, or does it crash, or can't you find your way around XFCE)I installed "Linuxcnc 2.8.0 buster.iso", nothing works, I can't even do an "Update my system".
[edit]
Last edit: 13 Jul 2021 13:01 by Aciera.
- JackRay
13 Jul 2021 12:59 #214575
by JackRay
As I said above I have a Xubuntu version with linuxcnc 2.9pre which works very well and is stable; is it possible to simply add the "SwichKins" branch to do 5axis TCP with "xyzac-trt.ini" on this version?
- JackRay
13 Jul 2021 13:10 #214577
by JackRay
I just say that I have failed with the terminal
jack@jack:~$ sudo apt-key adv --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
[sudo] Mot de passe de jack :
Executing: /tmp/apt-key-gpghome.BM7d7Ya14E/gpg.1.sh --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
gpg: échec de réception depuis le serveur de clefs : No name
jack@jack:~$ sudo apt-get install dirmngr
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
dirmngr est déjà la version la plus récente (2.2.12-1+deb10u1).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 122 non mis à jour.
jack@jack:~$ sudo apt-key adv --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E
Executing: /tmp/apt-key-gpghome.jHKNsl24Lc/gpg.1.sh --keyserver hkp://keys.gnupg.net:80 --recv-key EF1B07FEE0EE663E
Executing: /tmp/apt-key-gpghome.NHujYBZFIu/gpg.1.sh --keyserver hkp://keys.gnupg.net --recv-key EF1B07FEE0EE663E
13 Jul 2021 13:12 - 13 Jul 2021 13:17 #214578
Forget the "SwitchKins" branch it's been rolled into the current master (ie 2.9pre).
How did you get linuxcnc 2.9pre on that Xubuntu (ie deb install or rip install)?
I'm not familiar with Xubuntu but if it's a deb install you can try to add the repositories in the package manager ( or whatever it's called in Xubuntu) and see if you can update to current master.
If it's a rip install then you should have (most) of the dependencies installed and I would do a rip install again.
[edit]
Ok the key is not working for me either so that is not your fault. I'll see what I can find.
[edit]
Last edit: 13 Jul 2021 13:17 by Aciera.
13 Jul 2021 13:25 #214579
Ok, skip adding the key and try to add the repositories in the synaptic manager.
- JackRay
13 Jul 2021 15:18 #214595
by JackRay
Thanks, I also have a Linux Mint version with built-in linuxcnc 2.8. Can I do something with it, or is it better to do with Xubuntu.
I give you the link to download Xubutu Linuxcnc 2.9Pre RT 5.29
www.machmaker.pl/1_5_pliki-do-pobrania-downloads.html
13 Jul 2021 15:23 - 13 Jul 2021 15:25 #214597
you can certainly try to add the repositories in the xubuntu and in linuxmint and then check if you get the packages in synaptic.
Doesn't break anything if it doesn't work.
[edit]
there is quite a collection of ISO there.
[edit]
Last edit: 13 Jul 2021 15:25 by Aciera.
Time to create page: 0.485 seconds
