Hi All, I'm scratching my head on this one...Is there are simple explanation of what's needed in the HAL file to get something like an xyzac-trt with TCP machine configured? I see a lot of posts with snippets of HAL configs , talk of success and desirable features..I've read the PDF and doc page. There are no sample HAL and INI examples. I find the SIM stuff confusing.
What is different in the HAL config between simple 5axis trivkins xyzab and proper xyzac-trt or xyzbc-trt kinetmatics ? I understand the mathematics behind it , 3D transformations , rotations and translations etc. I understand the offsets for the vectors need to be specified somewhere, either in HAL or a file.
I have 5 axis trivkins working with a Mesa 5125+7i76 . If I set the kinematics to xyzab-trt I get five joints (0 to 4) in the Axis GUI. Where to from here? Does LinuxCNC assume each axis pivot is co-located , there are no translations? I would like Tool Center Point functionality and would like to see the X axis translate while the A axis is tilting the B or C axis to keep the work under the tool.
I'm using the latest version of LinuxCNC 2.8.2
Can I simply take an AXIS SIM config with xyzab-trt and modify it to work with actual hardware?
Thanks,
Peter.
