TCP 5-axis kinematics
4 years 9 months ago #232131 by Aciera
Replied by Aciera on topic TCP 5-axis kinematics
Not sure which post you are referring to exactly. If you have the kinematics for xyzbc and/or xyzac with rotary axis inverted as discussed above then please post them and I will try to put an example together using the 'userkins' template.
4 years 9 months ago #232135 by jsskangas
Replied by jsskangas on topic TCP 5-axis kinematics
Hello
I was trying with my own kinematics but got error:
modules/motmod.so: undefined symbol: kinematicsSwitch
Is there something I need to add to my own kinematic module if I want to use it?
4 years 9 months ago #232139 by dgarrett
Replied by dgarrett on topic TCP 5-axis kinematics
Kinematics modules that do not support kinematics switching use the macro "KINS_NOT_SWITCHABLE" provided by kinematics.h.
Ref code updates in master branch:
linuxcnc.org/docs/devel/html/getting-sta...c.html#_code_updates
linuxcnc.org/docs/devel/html/motion/switchkins.html
4 years 9 months ago - 4 years 9 months ago #232141 by jsskangas
dgarrett: If I use "KINS_NOT_SWITCHABLE" will it still be possible to update new location via M66 (sync new position to system) when I use my own switchable kinematics?
how I use this  "KINS_NOT_SWITCHABLE" ?
Last edit: 4 years 9 months ago by jsskangas.
4 years 9 months ago - 4 years 9 months ago #232157 by jsskangas
Got machine to start and in joint mode (not homed) all joints move and has correct feedback,
but when I try home machine joint 1 gives feedback error.
You can just but machine on again with out restarting linuxcnc and joints works perfectly.
Trying to re-home it gives same feedback error for joint 1.
It is not a real feedback error as all joints move correctly.
Any ideas why? Solved
4 years 9 months ago - 4 years 9 months ago #232231 by Aciera
Since your kinematic seems to use your own flavour of switchable kinematics (which will not be needed when using the built in switchable kinematics feature) it's not quite as simple as copy pasting it into the 'userkins.comp' template and since you are probably better versed in C then me I have made a component using the  current xyzbc-trt model, so it won't be what you want but it should give you an idea of how to adapt it to your needs.
File Name: xyzbc_trt.comp
File Size:8.03 KB
To compile it on a RIP installation:
$ halcompile --install <your-path>/xyzbc_trt.comp
(For a deb installation you will probably need to use 'sudo' with the above.)
If you want to test this you can use the simulation config /sim/axis/vismach/5axis/table-rotary-tilting/xyzbc-trt
To do so you will need to change xyzbc-trt.ini:
#KINEMATICS = xyzbc-trt-kins sparm=identityfirst
KINEMATICS = xyzbc_trt
# not currently supported by xyzbc-trt-gui:
#HALCMD = setp xyzbc-trt-kins.x-rot-point 0
#HALCMD = setp xyzbc-trt-kins.y-rot-point 0
#HALCMD = setp xyzbc-trt-kins.z-rot-point 0
[edit]
You might also want to have a look at the /sim/axis/vismach/millturn simulation config for an application of 'userkins.comp' template with switchable kinematics. 'millturn.comp' can be found at /src/hal/components
Last edit: 4 years 9 months ago by Aciera.
