- Thank you received: 6
xyzbc-trt-kins (switchkins)
Uses remapped user m codes for kins switch:
M429: Identity Kinematics
M428: XYZBC (TCP)
M430: userk Kinematics A
hal net is required to connect the analog out pin N,
Example (for N=3): net :kinstype-select <= motion.analog-out-03net :kinstype-select => motion.switchkins-type
Hal Input pins:xyzbc-trt-kins.x-offset, xyzbc-trt-kins.z-offset:
X and Z offsets are the offsets from the center of rotation of the B axis relative to the center of rotation of the C axis.
Hal Input pins:xyzac-trt-kins.x-rot-point, xyzac-trt-kins.y-rot-point, xyzac-trt-kins.z-rot-point:
X, Y and Z rot-point pins represent the offsets of the center of rotation of the C axisrelative to the machine absolute zero
