TCP 5-axis kinematics
4 years 5 months ago - 4 years 5 months ago #244061 by mittim
Replied by mittim on topic TCP 5-axis kinematics
I referenced xyzac-trt-kins in my .INI-file. I have an XYYZAC setup.
After starting LinuxCNC it shows 6 axis as joints. After homing, it shows x,y,z,a and c. Nothing wrong there.
My problem: my joints are not moving correctly. X moves fine, but only one of my y-axis-joints is moving. When trying to move z, it is moving y2 and so on... I guess LinuxCNC "forgets" my gantry setup in the xyzac-trt-kins setup.
Any suggestions, what´s the issue?
I should add, that I am homing on the spot manually for test purposes.
Last edit: 4 years 5 months ago by mittim.
4 years 5 months ago #244162 by andypugh
Replied by andypugh on topic TCP 5-axis kinematics
Are you passing the coordinate list to xyzac-trt-kins that matches your joint allocations?
Also, which version of LinuxCNC are you using? It looks like the version in 2.9 (unreleased development version) supports gantry axes, but the version in 2.8 does not.
4 years 5 months ago - 4 years 5 months ago #244300 by mittim
I am sorry, I don´t know how to pass the coordinate list to the xyzac-trt-kins. Where can I do that?
Do you mean the assignment in the INI file as: KINEMATICS = xyzac-trt-kins coordinates = xyyzac?
Is there anything else I need to assign in the HAL file?
I am using LinuxCNC 2.9
4 years 5 months ago #244302 by andypugh
That's what I meant. Is it not working?
4 years 5 months ago #244313 by andypugh
Try it without spaces around the = signs.
4 years 5 months ago - 4 years 4 months ago #244363 by mittim
Ist there anything I need to change in my hal file?
Getting the following error message.
Maybe hardcoding the trtfuncs.c could help? I would change the assignment of joint 3 from "JZ" to "JY2" and move any further joint according to that.
Last edit: 4 years 4 months ago by mittim.
Time to create page: 0.424 seconds
