TCP 5-axis kinematics
4 years 4 months ago #244599 by jurod
Replied by jurod on topic TCP 5-axis kinematics
Still getting the same error message from LinuxCNC when changing
coordinates=xyyzac to coordinates=xyzacy.
have you reworked the entire HAL?  AxisX=joint0=stepgen00=coordinates=x
                                                           AxisY=joint1=stepgen01=coordinates=y
                                                           AxisZ=joint2=stepgen03=coordinates=z
                                                           AxisY2=joint6=stepgen02=coordinates=y
4 years 4 months ago - 4 years 4 months ago #244602 by mittim
Replied by mittim on topic TCP 5-axis kinematics
Thanks for the reply. I changed the joint numbers in my HAL and INI according to xyzacy. Still getting the same error message.
# Erstellt von PNCconf am Sat May 21 09:49:44 2022 # Using LinuxCNC version:  Master (2.9) # Änderungen an dieser Datei werden beim nächsten # overwritten when you run PNCconf again loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS loadrt hostmot2 loadrt hm2_eth board_ip="192.168.1.121" config=" num_encoders=1 num_pwmgens=1 num_stepgens=6 sserial_port_0=0xxxxx"  setp    hm2_7i95.0.watchdog.timeout_ns 5000000 loadrt pid names=pid.x,pid.y,pid.y2,pid.z,pid.a,pid.c,pid.s loadusr -W xhc-whb04b-6 -H  addf hm2_7i95.0.read          servo-thread addf motion-command-handler   servo-thread addf motion-controller        servo-thread addf pid.x.do-pid-calcs       servo-thread addf pid.y.do-pid-calcs       servo-thread addf pid.y2.do-pid-calcs      servo-thread addf pid.z.do-pid-calcs       servo-thread addf pid.a.do-pid-calcs       servo-thread addf pid.c.do-pid-calcs       servo-thread addf pid.s.do-pid-calcs       servo-thread addf hm2_7i95.0.write         servo-thread # external output signals #net <OIL> hm2_7i95.0.ssr.00.out-00 net kss hm2_7i95.0.ssr.00.out-04 #net <WERKZEUG> hm2_7i95.0.ssr.00.out-02 #net <name> hm2_7i95.0.ssr.00.out-03 net spindle_on_off    hm2_7i95.0.ssr.00.out-03 #net <name> hm2_7i95.0.ssr.00.out-05 # external input signals net motorerror         hm2_7i95.0.inmux.00.input-15 net x-home-sw         hm2_7i95.0.inmux.00.input-23 net a-pos-limit     hm2_7i95.0.inmux.00.input-06-not net y-pos-limit     hm2_7i95.0.inmux.00.input-11 net y-home-sw         hm2_7i95.0.inmux.00.input-02-not     net y2-home-sw        hm2_7i95.0.inmux.00.input-05-not net x-pos-limit     hm2_7i95.0.inmux.00.input-09-not net a-home-sw        hm2_7i95.0.inmux.00.input-03-not net z-neg-limit     hm2_7i95.0.inmux.00.input-04-not net z-home-sw        hm2_7i95.0.inmux.00.input-08-not net estop-out        hm2_7i95.0.inmux.00.input-07 #net <name> hm2_7i95.0.inmux.00.input-07 #net <name> hm2_7i95.0.inmux.00.input-10 #net <name> hm2_7i95.0.inmux.00.input-11 net kss hm2_7i95.0.inmux.00.input-12 #net <name> hm2_7i95.0.inmux.00.input-13 #net <name> hm2_7i95.0.inmux.00.input-15 #net <name> hm2_7i95.0.inmux.00.input-16 #net <name> hm2_7i95.0.inmux.00.input-17 #net <name> hm2_7i95.0.inmux.00.input-18 #net <name> hm2_7i95.0.inmux.00.input-19 #net <name> hm2_7i95.0.inmux.00.input-20 #net <name> hm2_7i95.0.inmux.00.input-21 #net <name> hm2_7i95.0.inmux.00.input-22 #net <name> hm2_7i95.0.inmux.00.input-23 #******************************************************************************************************************************************************** #  AXIS X JOINT 0 #******************************************************************************************************************************************************** setp   pid.x.Pgain     [JOINT_0]P setp   pid.x.Igain     [JOINT_0]I setp   pid.x.Dgain     [JOINT_0]D setp   pid.x.bias      [JOINT_0]BIAS setp   pid.x.FF0       [JOINT_0]FF0 setp   pid.x.FF1       [JOINT_0]FF1 setp   pid.x.FF2       [JOINT_0]FF2 setp   pid.x.deadband  [JOINT_0]DEADBAND setp   pid.x.maxoutput [JOINT_0]MAX_OUTPUT setp   pid.x.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.x.maxerror 0.012700 net x-index-enable  <=> pid.x.index-enable net x-enable        =>  pid.x.enable net x-pos-cmd       =>  pid.x.command net x-pos-fb        =>  pid.x.feedback net x-output        <=  pid.x.output # Step Gen signals/setup setp   hm2_7i95.0.stepgen.00.dirsetup         [JOINT_0]DIRSETUP setp   hm2_7i95.0.stepgen.00.dirhold          [JOINT_0]DIRHOLD setp   hm2_7i95.0.stepgen.00.steplen          [JOINT_0]STEPLEN setp   hm2_7i95.0.stepgen.00.stepspace        [JOINT_0]STEPSPACE setp   hm2_7i95.0.stepgen.00.position-scale   [JOINT_0]STEP_SCALE setp   hm2_7i95.0.stepgen.00.step_type        0 setp   hm2_7i95.0.stepgen.00.control-type     1 setp   hm2_7i95.0.stepgen.00.maxaccel         [JOINT_0]STEPGEN_MAXACCEL setp   hm2_7i95.0.stepgen.00.maxvel           [JOINT_0]STEPGEN_MAXVEL # ---closedloop stepper signals--- net x-pos-cmd    <= joint.0.motor-pos-cmd net x-vel-cmd    <= joint.0.vel-cmd net x-output     <= hm2_7i95.0.stepgen.00.velocity-cmd net x-pos-fb     <= hm2_7i95.0.stepgen.00.position-fb net x-pos-fb     => joint.0.motor-pos-fb net x-enable     <= joint.0.amp-enable-out net x-enable     => hm2_7i95.0.stepgen.00.enable # ---setup home / limit switch signals--- net x-home-sw       =>  joint.0.home-sw-in        joint.0.neg-lim-sw-in net x-pos-limit     =>  joint.0.pos-lim-sw-in #******************************************************************************************************************************************************** #  AXIS Y JOINT 1 #******************************************************************************************************************************************************** setp   pid.y.Pgain     [JOINT_1]P setp   pid.y.Igain     [JOINT_1]I setp   pid.y.Dgain     [JOINT_1]D setp   pid.y.bias      [JOINT_1]BIAS setp   pid.y.FF0       [JOINT_1]FF0 setp   pid.y.FF1       [JOINT_1]FF1 setp   pid.y.FF2       [JOINT_1]FF2 setp   pid.y.deadband  [JOINT_1]DEADBAND setp   pid.y.maxoutput [JOINT_1]MAX_OUTPUT setp   pid.y.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.y.maxerror 0.012700 net y-index-enable  <=> pid.y.index-enable net y-enable        =>  pid.y.enable net y-pos-cmd       =>  pid.y.command net y-pos-fb        =>  pid.y.feedback net y-output        <=  pid.y.output # Step Gen signals/setup setp   hm2_7i95.0.stepgen.01.dirsetup         [JOINT_1]DIRSETUP setp   hm2_7i95.0.stepgen.01.dirhold          [JOINT_1]DIRHOLD setp   hm2_7i95.0.stepgen.01.steplen          [JOINT_1]STEPLEN setp   hm2_7i95.0.stepgen.01.stepspace        [JOINT_1]STEPSPACE setp   hm2_7i95.0.stepgen.01.position-scale   [JOINT_1]STEP_SCALE setp   hm2_7i95.0.stepgen.01.step_type        0 setp   hm2_7i95.0.stepgen.01.control-type     1 setp   hm2_7i95.0.stepgen.01.maxaccel         [JOINT_1]STEPGEN_MAXACCEL setp   hm2_7i95.0.stepgen.01.maxvel           [JOINT_1]STEPGEN_MAXVEL # ---closedloop stepper signals--- net y-pos-cmd    <= joint.1.motor-pos-cmd net y-vel-cmd    <= joint.1.vel-cmd net y-output     <= hm2_7i95.0.stepgen.01.velocity-cmd net y-pos-fb     <= hm2_7i95.0.stepgen.01.position-fb net y-pos-fb     => joint.1.motor-pos-fb net y-enable     <= joint.1.amp-enable-out net y-enable     => hm2_7i95.0.stepgen.01.enable # ---setup home / limit switch signals--- net y-home-sw       =>  joint.1.home-sw-in        joint.1.neg-lim-sw-in net y-pos-limit     =>  joint.1.pos-lim-sw-in #******************************************************************************************************************************************************** #  AXIS Y JOINT 5 #******************************************************************************************************************************************************** setp   pid.y2.Pgain     [JOINT_5]P setp   pid.y2.Igain     [JOINT_5]I setp   pid.y2.Dgain     [JOINT_5]D setp   pid.y2.bias      [JOINT_5]BIAS setp   pid.y2.FF0       [JOINT_5]FF0 setp   pid.y2.FF1       [JOINT_5]FF1 setp   pid.y2.FF2       [JOINT_5]FF2 setp   pid.y2.deadband  [JOINT_5]DEADBAND setp   pid.y2.maxoutput [JOINT_5]MAX_OUTPUT setp   pid.y2.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.y2.maxerror 0.012700 net y2-index-enable  <=> pid.y2.index-enable net y2-enable        =>  pid.y2.enable net y2-pos-cmd       =>  pid.y2.command net y2-pos-fb        =>  pid.y2.feedback net y2-output        <=  pid.y2.output # Step Gen signals/setup setp   hm2_7i95.0.stepgen.02.dirsetup         [JOINT_5]DIRSETUP setp   hm2_7i95.0.stepgen.02.dirhold          [JOINT_5]DIRHOLD setp   hm2_7i95.0.stepgen.02.steplen          [JOINT_5]STEPLEN setp   hm2_7i95.0.stepgen.02.stepspace        [JOINT_5]STEPSPACE setp   hm2_7i95.0.stepgen.02.position-scale   [JOINT_5]STEP_SCALE setp   hm2_7i95.0.stepgen.02.step_type        0 setp   hm2_7i95.0.stepgen.02.control-type     1 setp   hm2_7i95.0.stepgen.02.maxaccel         [JOINT_5]STEPGEN_MAXACCEL setp   hm2_7i95.0.stepgen.02.maxvel           [JOINT_5]STEPGEN_MAXVEL # ---closedloop stepper signals--- net y2-pos-cmd    <= joint.2.motor-pos-cmd net y2-vel-cmd    <= joint.2.vel-cmd net y2-output     <= hm2_7i95.0.stepgen.02.velocity-cmd net y2-pos-fb     <= hm2_7i95.0.stepgen.02.position-fb net y2-pos-fb     => joint.2.motor-pos-fb net y2-enable     <= joint.2.amp-enable-out net y2-enable     => hm2_7i95.0.stepgen.02.enable # ---setup home / limit switch signals--- net y2-home-sw       =>  joint.2.home-sw-in        joint.2.neg-lim-sw-in net y2-pos-limit     =>  joint.2.pos-lim-sw-in #******************************************************************************************************************************************************** #  AXIS Z JOINT 2 #******************************************************************************************************************************************************** setp   pid.z.Pgain     [JOINT_2]P setp   pid.z.Igain     [JOINT_2]I setp   pid.z.Dgain     [JOINT_2]D setp   pid.z.bias      [JOINT_2]BIAS setp   pid.z.FF0       [JOINT_2]FF0 setp   pid.z.FF1       [JOINT_2]FF1 setp   pid.z.FF2       [JOINT_2]FF2 setp   pid.z.deadband  [JOINT_2]DEADBAND setp   pid.z.maxoutput [JOINT_2]MAX_OUTPUT setp   pid.z.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.z.maxerror 0.012700 net z-index-enable  <=> pid.z.index-enable net z-enable        =>  pid.z.enable net z-pos-cmd       =>  pid.z.command net z-pos-fb        =>  pid.z.feedback net z-output        <=  pid.z.output # Step Gen signals/setup setp   hm2_7i95.0.stepgen.03.dirsetup         [JOINT_2]DIRSETUP setp   hm2_7i95.0.stepgen.03.dirhold          [JOINT_2]DIRHOLD setp   hm2_7i95.0.stepgen.03.steplen          [JOINT_2]STEPLEN setp   hm2_7i95.0.stepgen.03.stepspace        [JOINT_2]STEPSPACE setp   hm2_7i95.0.stepgen.03.position-scale   [JOINT_2]STEP_SCALE setp   hm2_7i95.0.stepgen.03.step_type        0 setp   hm2_7i95.0.stepgen.03.control-type     1 setp   hm2_7i95.0.stepgen.03.maxaccel         [JOINT_2]STEPGEN_MAXACCEL setp   hm2_7i95.0.stepgen.03.maxvel           [JOINT_2]STEPGEN_MAXVEL # ---closedloop stepper signals--- net z-pos-cmd    <= joint.3.motor-pos-cmd net z-vel-cmd    <= joint.3.vel-cmd net z-output     <= hm2_7i95.0.stepgen.03.velocity-cmd net z-pos-fb     <= hm2_7i95.0.stepgen.03.position-fb net z-pos-fb     => joint.3.motor-pos-fb net z-enable     <= joint.3.amp-enable-out net z-enable     => hm2_7i95.0.stepgen.03.enable # ---setup home / limit switch signals--- net z-home-sw       =>  joint.3.home-sw-in        joint.3.neg-lim-sw-in net z-pos-limit     =>  joint.3.pos-lim-sw-in #******************************************************************************************************************************************************** #  AXIS A JOINT 3 #******************************************************************************************************************************************************** setp   pid.a.Pgain     [JOINT_3]P setp   pid.a.Igain     [JOINT_3]I setp   pid.a.Dgain     [JOINT_3]D setp   pid.a.bias      [JOINT_3]BIAS setp   pid.a.FF0       [JOINT_3]FF0 setp   pid.a.FF1       [JOINT_3]FF1 setp   pid.a.FF2       [JOINT_3]FF2 setp   pid.a.deadband  [JOINT_3]DEADBAND setp   pid.a.maxoutput [JOINT_3]MAX_OUTPUT setp   pid.a.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.a.maxerror 0.012700 net a-index-enable  <=> pid.a.index-enable net a-enable        =>  pid.a.enable net a-pos-cmd       =>  pid.a.command net a-pos-fb        =>  pid.a.feedback net a-output        <=  pid.a.output # Step Gen signals/setup setp   hm2_7i95.0.stepgen.04.dirsetup        [JOINT_3]DIRSETUP setp   hm2_7i95.0.stepgen.04.dirhold         [JOINT_3]DIRHOLD setp   hm2_7i95.0.stepgen.04.steplen         [JOINT_3]STEPLEN setp   hm2_7i95.0.stepgen.04.stepspace       [JOINT_3]STEPSPACE setp   hm2_7i95.0.stepgen.04.position-scale  [JOINT_3]STEP_SCALE setp   hm2_7i95.0.stepgen.04.step_type        0 setp   hm2_7i95.0.stepgen.04.control-type     1 setp   hm2_7i95.0.stepgen.04.maxaccel         [JOINT_3]STEPGEN_MAXACCEL setp   hm2_7i95.0.stepgen.04.maxvel           [JOINT_3]STEPGEN_MAXVEL net a-pos-cmd    <= joint.4.motor-pos-cmd net a-vel-cmd    <= joint.4.vel-cmd net a-output     <= hm2_7i95.0.stepgen.04.velocity-cmd net a-pos-fb     <= hm2_7i95.0.stepgen.04.position-fb net a-pos-fb     => joint.4.motor-pos-fb net a-enable     <= joint.4.amp-enable-out net a-enable     => hm2_7i95.0.stepgen.04.enable # ---setup home / limit switch signals--- net a-home-sw       =>  joint.4.home-sw-in        joint.4.neg-lim-sw-in net a-pos-limit     =>  joint.4.pos-lim-sw-in #******************************************************************************************************************************************************** #  AXIS C JOINT 4 #******************************************************************************************************************************************************** setp   pid.c.Pgain     [JOINT_4]P setp   pid.c.Igain     [JOINT_4]I setp   pid.c.Dgain     [JOINT_4]D setp   pid.c.bias      [JOINT_4]BIAS setp   pid.c.FF0       [JOINT_4]FF0 setp   pid.c.FF1       [JOINT_4]FF1 setp   pid.c.FF2       [JOINT_4]FF2 setp   pid.c.deadband  [JOINT_4]DEADBAND setp   pid.c.maxoutput [JOINT_4]MAX_OUTPUT setp   pid.c.error-previous-target true # This setting is to limit bogus stepgen # velocity corrections caused by position # feedback sample time jitter. setp   pid.a.maxerror 0.012700 net c-index-enable  <=> pid.c.index-enable net c-enable        =>  pid.c.enable net c-pos-cmd       =>  pid.c.command net c-pos-fb        =>  pid.c.feedback net c-output        <=  pid.c.output # Step Gen signals/setup setp   hm2_7i95.0.stepgen.05.dirsetup        [JOINT_4]DIRSETUP setp   hm2_7i95.0.stepgen.05.dirhold         [JOINT_4]DIRHOLD setp   hm2_7i95.0.stepgen.05.steplen         [JOINT_4]STEPLEN setp   hm2_7i95.0.stepgen.05.stepspace       [JOINT_4]STEPSPACE setp   hm2_7i95.0.stepgen.05.position-scale  [JOINT_4]STEP_SCALE setp   hm2_7i95.0.stepgen.05.step_type        0 setp   hm2_7i95.0.stepgen.05.control-type     1 setp   hm2_7i95.0.stepgen.05.maxaccel         [JOINT_4]STEPGEN_MAXACCEL setp   hm2_7i95.0.stepgen.05.maxvel           [JOINT_4]STEPGEN_MAXVEL # ---closedloop stepper signals--- net c-pos-cmd    <= joint.5.motor-pos-cmd net c-vel-cmd    <= joint.5.vel-cmd net c-output     <= hm2_7i95.0.stepgen.05.velocity-cmd #net c-pos-fb     <= hm2_7i95.0.stepgen.05.position-fb net c-pos-fb     => joint.5.motor-pos-fb net c-enable     <= joint.5.amp-enable-out net c-enable     => hm2_7i95.0.stepgen.05.enable # ---Encoder feedback signals/setup--- setp    hm2_7i95.0.encoder.00.counter-mode 0 setp    hm2_7i95.0.encoder.00.filter 1 setp    hm2_7i95.0.encoder.00.index-invert 0 setp    hm2_7i95.0.encoder.00.index-mask 0 setp    hm2_7i95.0.encoder.00.index-mask-invert 0 setp    hm2_7i95.0.encoder.00.scale  [JOINT_4]ENCODER_SCALE net c-pos-fb               <=  hm2_7i95.0.encoder.00.position net c-vel-fb               <=  hm2_7i95.0.encoder.00.velocity net c-pos-fb               =>  joint.5.motor-pos-fb net c-index-enable    joint.5.index-enable  <=>  hm2_7i95.0.encoder.00.index-enable net c-pos-rawcounts        <=  hm2_7i95.0.encoder.00.rawcounts # ---setup home / limit switch signals--- net c-home-sw     =>  joint.5.home-sw-in #net c-neg-limit     =>  joint.5.neg-lim-sw-in #net c-pos-limit     =>  joint.5.pos-lim-sw-in #******************************************************************************************************************************************************** #  SPINDLE #******************************************************************************************************************************************************** setp   pid.s.Pgain     [SPINDLE_0]P setp   pid.s.Igain     [SPINDLE_0]I setp   pid.s.Dgain     [SPINDLE_0]D setp   pid.s.bias      [SPINDLE_0]BIAS setp   pid.s.FF0       [SPINDLE_0]FF0 setp   pid.s.FF1       [SPINDLE_0]FF1 setp   pid.s.FF2       [SPINDLE_0]FF2 setp   pid.s.deadband  [SPINDLE_0]DEADBAND setp   pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT setp   pid.s.error-previous-target true net spindle-index-enable  <=>  pid.s.index-enable net spindle-enable        =>   pid.s.enable net spindle-vel-cmd-rpm   =>   pid.s.command net spindle-vel-fb-rpm    =>   pid.s.feedback net spindle-output        <=   pid.s.output # ---setup spindle control signals--- net spindle-vel-cmd-rps        <=  spindle.0.speed-out-rps net spindle-vel-cmd-rps-abs    <=  spindle.0.speed-out-rps-abs net spindle-vel-cmd-rpm        <=  spindle.0.speed-out net spindle-vel-cmd-rpm-abs    <=  spindle.0.speed-out-abs net spindle-enable             <=  spindle.0.on net spindle-cw                 <=  spindle.0.forward net spindle-ccw                <=  spindle.0.reverse net spindle-brake              <=  spindle.0.brake net spindle-revs               =>  spindle.0.revs net spindle-at-speed           =>  spindle.0.at-speed net spindle-vel-fb-rps         =>  spindle.0.speed-in net spindle-index-enable      <=>  spindle.0.index-enable # ---Setup spindle at speed signals--- ######## S1000    2.9 ######## S2000    4.2 ######## S3000    5.5 ######## S4000    6.9 ######## S5000    8.2 ######## S6000    9.4 ######## S6600    10.0 sets spindle-at-speed true setp hm2_7i95.0.pwmgen.pwm_frequency 3000 setp hm2_7i95.0.pwmgen.00.scale 7500 setp hm2_7i95.0.pwmgen.00.offset-mode 0 net spindle-enable spindle.0.on => hm2_7i95.0.pwmgen.00.enable net spindle-vel-cmd-rpm-abs spindle.0.speed-out-abs hm2_7i95.0.pwmgen.00.value #****************************** # connect miscellaneous signals #****************************** #  ---HALUI signals--- net axis-select-x  halui.axis.x.select net jog-x-pos      halui.axis.x.plus net jog-x-neg      halui.axis.x.minus net jog-x-analog   halui.axis.x.analog net x-is-homed     halui.joint.0.is-homed net axis-select-y  halui.axis.y.select net jog-y-pos      halui.axis.y.plus net jog-y-neg      halui.axis.y.minus net jog-y-analog   halui.axis.y.analog net y-is-homed     halui.joint.1.is-homed net axis-select-z  halui.axis.z.select net jog-z-pos      halui.axis.z.plus net jog-z-neg      halui.axis.z.minus net jog-z-analog   halui.axis.z.analog net z-is-homed     halui.joint.2.is-homed net axis-select-a  halui.axis.a.select net jog-a-pos      halui.axis.a.plus net jog-a-neg      halui.axis.a.minus net jog-a-analog   halui.axis.a.analog net a-is-homed     halui.joint.3.is-homed net axis-select-c  halui.axis.c.select net jog-c-pos      halui.axis.c.plus net jog-c-neg      halui.axis.c.minus net jog-c-analog   halui.axis.c.analog net c-is-homed     halui.joint.4.is-homed net jog-selected-pos      halui.axis.selected.plus net jog-selected-neg      halui.axis.selected.minus net spindle-manual-cw     halui.spindle.0.forward net spindle-manual-ccw    halui.spindle.0.reverse net spindle-manual-stop   halui.spindle.0.stop net machine-is-on         halui.machine.is-on        whb.halui.machine.is-on net jog-speed             halui.axis.jog-speed net MDI-mode              halui.mode.is-mdi #  ---coolant signals--- net coolant-mist      <=  iocontrol.0.coolant-mist net coolant-flood     <=  iocontrol.0.coolant-flood #  ---probe signal--- net probe-in     =>  motion.probe-input #  ---motion control signals--- net in-position               <=  motion.in-position net machine-is-enabled        <=  motion.motion-enabled #  ---digital in / out signals--- #  ---estop signals--- net estop-out     =>  iocontrol.0.emc-enable-in net motorerror        joint.0.amp-fault-in #  ---manual tool change signals--- loadusr -W hal_manualtoolchange net tool-change-request     iocontrol.0.tool-change       =>  hal_manualtoolchange.change net tool-change-confirmed   iocontrol.0.tool-changed      <=  hal_manualtoolchange.changed net tool-number             iocontrol.0.tool-prep-number  =>  hal_manualtoolchange.number net tool-prepare-loopback   iocontrol.0.tool-prepare      =>  iocontrol.0.tool-prepared ################# # ######################################################################     # WHB04B-6 jog dial configuration     # ######################################################################     # BEGIN Note: spindle signals are ususally listed in the main .hal file     #     #net  spindle.is-on                      motion.spindle-on     #net  spindle.start                      halui.spindle.start              #net  spindle.stop                       halui.spindle.stop     #net  spindle.forward                    halui.spindle.forward     #     #net  spindle.reverse                    halui.spindle.reverse     #net  spindle.runs-forward               motion.spindle-forward          #net  spindle.runs-reverse               motion.spindle-reverse     #     #net  spindle.increase                   halui.spindle.increase     #net  spindle.decrease                   halui.spindle.decrease     #net  spindle.spindle-override.value     halui.spindle-override.value     #net  spindle.spindle-override.increase  halui.spindle-override.increase     #net  spindle.spindle-override.decrease  halui.spindle-override.decrease     #     #net  spindle.velocity.abs-rpm           motion.spindle-speed-out-abs     #     # END Note     # ######################################################################     # Load components     # ######################################################################     loadrt ilowpass names=ilowpass.jog.x,ilowpass.jog.y,ilowpass.jog.z,ilowpass.jog.a,ilowpass.jog.c     addf   ilowpass.jog.x       servo-thread     addf   ilowpass.jog.y       servo-thread     addf   ilowpass.jog.z       servo-thread     addf   ilowpass.jog.a       servo-thread     addf   ilowpass.jog.c       servo-thread     setp   ilowpass.jog.x.scale 100     setp   ilowpass.jog.y.scale 100     setp   ilowpass.jog.z.scale 100     setp   ilowpass.jog.a.scale 100     setp   ilowpass.jog.c.scale 100     setp   ilowpass.jog.x.gain  0.01     setp   ilowpass.jog.y.gain  0.01     setp   ilowpass.jog.z.gain  0.01     setp   ilowpass.jog.a.gain  0.01     setp   ilowpass.jog.c.gain  0.01     loadrt scale names=scale.axis.x,scale.axis.y,scale.axis.z,scale.axis.a,scale.axis.c     addf   scale.axis.x         servo-thread     addf   scale.axis.y         servo-thread     addf   scale.axis.z         servo-thread     addf   scale.axis.a         servo-thread     addf   scale.axis.c         servo-thread     setp   scale.axis.x.gain    0.01      setp   scale.axis.y.gain    0.01      setp   scale.axis.z.gain    0.01     setp   scale.axis.a.gain    0.01     setp   scale.axis.c.gain    0.01         setp   scale.axis.x.offset  0     setp   scale.axis.y.offset  0     setp   scale.axis.z.offset  0     setp   scale.axis.a.offset  0     setp   scale.axis.c.offset  0     # ######################################################################     # Signals configuration     # ######################################################################     # Connect emergency stop signals     #net  pdnt.machine.is-on                  halui.machine.is-on                whb.halui.machine.is-on     net  pdnt.machine.on                     whb.halui.machine.on               halui.machine.on     net  pdnt.machine.off                    whb.halui.machine.off              halui.machine.off     # Connect program related signals     net  pdnt.program.is-idle                whb.halui.program.is-idle          halui.program.is-idle     net  pdnt.program.is-paused              whb.halui.program.is-paused        halui.program.is-paused     net  pdnt.program.is-running             whb.halui.program.is-running       halui.program.is-running     net  pdnt.program.resume                 whb.halui.program.resume           halui.program.resume     net  pdnt.program.pause                  whb.halui.program.pause            halui.program.pause     net  pdnt.program.run                    whb.halui.program.run              halui.program.run     net  pdnt.program.stop                   whb.halui.program.stop             halui.program.stop     # Connect "selected axis" signals         net  pdnt.joint.X.select                 whb.halui.joint.x.select           halui.joint.0.select     net  pdnt.joint.Y.select                 whb.halui.joint.y.select           halui.joint.1.select     net  pdnt.joint.Z.select                 whb.halui.joint.z.select           halui.joint.2.select     net  pdnt.joint.A.select                 whb.halui.joint.a.select           halui.joint.3.select     net  pdnt.joint.C.select                 whb.halui.joint.c.select           halui.joint.4.select     # Connect jog signals for step and continuous mode     #net  pdnt.stepgen.00.maxvel              hpg.stepgen.00.maxvel              whb.stepgen.00.maxvel     #net  pdnt.stepgen.01.maxvel              hpg.stepgen.01.maxvel              whb.stepgen.01.maxvel     #net  pdnt.stepgen.02.maxvel              hpg.stepgen.02.maxvel              whb.stepgen.02.maxvel     #net  pdnt.stepgen.03.maxvel              hpg.stepgen.03.maxvel              whb.stepgen.03.maxvel     #net  pdnt.stepgen.00.position-scale      hpg.stepgen.00.position-scale      whb.stepgen.00.position-scale     #net  pdnt.stepgen.01.position-scale      hpg.stepgen.01.position-scale      whb.stepgen.01.position-scale     #net  pdnt.stepgen.02.position-scale      hpg.stepgen.02.position-scale      whb.stepgen.02.position-scale     #net  pdnt.stepgen.03.position-scale      hpg.stepgen.03.position-scale      whb.stepgen.03.position-scale     net  pdnt.axis.0.jog-scale               whb.axis.0.jog-scale               scale.axis.x.in           net  pdnt.axis.1.jog-scale               whb.axis.1.jog-scale               scale.axis.y.in           net  pdnt.axis.2.jog-scale               whb.axis.2.jog-scale               scale.axis.z.in       net  pdnt.axis.3.jog-scale               whb.axis.3.jog-scale               scale.axis.a.in       net  pdnt.axis.5.jog-scale               whb.axis.5.jog-scale               scale.axis.c.in        net  scale.axis.0.jog-scale              scale.axis.x.out                   axis.x.jog-scale     net  scale.axis.1.jog-scale              scale.axis.y.out                   axis.y.jog-scale     net  scale.axis.2.jog-scale              scale.axis.z.out                   axis.z.jog-scale     net  scale.axis.3.jog-scale              scale.axis.a.out                   axis.a.jog-scale     net  scale.axis.5.jog-scale              scale.axis.c.out                   axis.c.jog-scale     net  pdnt.axis.0.jog-counts              whb.axis.0.jog-counts              ilowpass.jog.x.in     net  pdnt.axis.1.jog-counts              whb.axis.1.jog-counts              ilowpass.jog.y.in     net  pdnt.axis.2.jog-counts              whb.axis.2.jog-counts              ilowpass.jog.z.in     net  pdnt.axis.3.jog-counts              whb.axis.3.jog-counts              ilowpass.jog.a.in     net  pdnt.axis.5.jog-counts              whb.axis.5.jog-counts              ilowpass.jog.c.in     net  pdnt.ilowpass.jog.0.jog-counts      ilowpass.jog.x.out                 axis.x.jog-counts     net  pdnt.ilowpass.jog.1.jog-counts      ilowpass.jog.y.out                 axis.y.jog-counts     net  pdnt.ilowpass.jog.2.jog-counts      ilowpass.jog.z.out                 axis.z.jog-counts     net  pdnt.ilowpass.jog.3.jog-counts      ilowpass.jog.a.out                 axis.a.jog-counts     net  pdnt.ilowpass.jog.4.jog-counts      ilowpass.jog.c.out                 axis.c.jog-counts     net  pdnt.axis.0.jog-enable              whb.axis.0.jog-enable              axis.x.jog-enable     net  pdnt.axis.1.jog-enable              whb.axis.1.jog-enable              axis.y.jog-enable     net  pdnt.axis.2.jog-enable              whb.axis.2.jog-enable              axis.z.jog-enable     net  pdnt.axis.3.jog-enable               whb.axis.3.jog-enable              axis.a.jog-enable     net  pdnt.axis.5.jog-enable               whb.axis.5.jog-enable              axis.c.jog-enable     net  pdnt.axis.0.jog-vel-mode            whb.axis.0.jog-vel-mode            axis.x.jog-vel-mode     net  pdnt.axis.1.jog-vel-mode            whb.axis.1.jog-vel-mode            axis.y.jog-vel-mode     net  pdnt.axis.2.jog-vel-mode            whb.axis.2.jog-vel-mode            axis.z.jog-vel-mode     net  pdnt.axis.3.jog-vel-mode            whb.axis.3.jog-vel-mode            axis.a.jog-vel-mode     net  pdnt.axis..jog-vel-mode            whb.axis.5.jog-vel-mode            axis.c.jog-vel-mode     # Connect macro buttons to mdi commands     #net pdnt.macro.1                        whb.button.macro-1                 halui.mdi-command-01     #net pdnt.macro.2                        whb.button.macro-2                 halui.mdi-command-02     #net pdnt.macro.3                        whb.button.macro-3                   halui.mdi-command-03     #net pdnt.macro.4                        whb.button.macro-4                 halui.mdi-command-04     #net pdnt.macro.6                        whb.button.macro-6                 halui.mdi-command-06                       #net pdnt.macro.8                        whb.button.macro-8                 halui.mdi-command-08     #net pdnt.macro.9                        whb.button.macro-9                 halui.mdi-command-09     #net pdnt.macro.10                       whb.button.macro-10                halui.mdi-command-10     #net pdnt.macro.11                       whb.button.macro-11                halui.mdi-command-11     #net pdnt.macro.12                       whb.button.macro-12                halui.mdi-command-12     #net pdnt.macro.13                       whb.button.macro-13                halui.home-all     #net pdnt.macro.14                       whb.button.macro-14                halui.mdi-command-14     #net pdnt.macro.15                       whb.button.macro-15                halui.mdi-command-15     #net pdnt.macro.16                       whb.button.macro-16                halui.mdi-command-16     # Connect reset, stop, start/pause/resume buttons to halui     # toggles whb.halui.estop.{activate, reset} which are     # already connected to halui.estop.{activate, reset} via whb.halui.estop.{activate, reset}     net  pdnt.button.reset                   whb.button.reset     # already linked to halui.program.stop via whb.program.stop     net  pdnt.button.stop                    whb.button.stop     # toggles whb.halui.program{run, pause, resume} which are      # already connected to halui.program.{run, pause, resume} via whb.halui.program.{run, pause, resume}     net  pdnt.button.start-pause             whb.button.start-pause          # Connect special positions signals     #net  pdnt.button.m-home                  whb.button.m-home                  halui.mdi-command-05     #net  pdnt.button.safe-z                  whb.button.safe-z                  halui.mdi-command-17     #net  pdnt.button.w-home                  whb.button.w-home                  halui.mdi-command-07     #net  pdnt.button.s-on-off                whb.button.s-on-off                halui.mdi-command-18     # unused, just exposes pendant interna     net pdnt.button.fn                       whb.button.fn     # probe command     #net  pdnt.button.probe-z                 whb.button.probe-z                halui.mdi-command-19     # unused, just exposes pendant interna     net  pdnt.button.mode-continuous         whb.button.mode-continuous     # unused, just exposes pendant interna     net  pdnt.button.mode-step               whb.button.mode-step     # Connect spindle related signals     net  spindle.is-on                       whb.halui.spindle.is-on     net  spindle.stop                        whb.halui.spindle.stop     net  spindle.forward                     whb.halui.spindle.forward     net  spindle.reverse                     whb.halui.spindle.reverse     # min/max override depends on [DISPLAY]MIN_SPINDLE_OVERRIDE and [DISPLAY]MAX_SPINDLE_OVERRIDE     net  spindle.spindle-override.value      whb.halui.spindle-override.value        halui.spindle.0.override.value     net  spindle.spindle-override.increase   whb.halui.spindle-override.increase    halui.spindle.0.override.increase     net  spindle.spindle-override.decrease   whb.halui.spindle-override.decrease    halui.spindle.0.override.decrease     net  spindle.velocity.abs-rpm            whb.motion.spindle-speed-abs     # Connect machine mode related signals     net  pdnt.halui.mode.auto                whb.halui.mode.auto                halui.mode.auto     net  pdnt.halui.mode.joint               whb.halui.mode.joint               halui.mode.joint     net  pdnt.halui.mode.manual              whb.halui.mode.manual              halui.mode.manual     #net  pdnt.halui.mode.mdi                 whb.halui.mode.mdi                 halui.mode.mdi     net  pdnt.halui.mode.is-auto             halui.mode.is-auto                 whb.halui.mode.is-auto     net  pdnt.halui.mode.is-joint            halui.mode.is-joint                whb.halui.mode.is-joint     net  pdnt.halui.mode.is-manual           halui.mode.is-manual               whb.halui.mode.is-manual     #net  pdnt.halui.mode.is-mdi              halui.mode.is-mdi                  whb.halui.mode.is-mdi     # Connect feed rate related signals     net  pdnt.halui.feed-override.scale        whb.halui.feed-override.scale        halui.feed-override.scale     net  pdnt.halui.feed-override.direct-val   whb.halui.feed-override.direct-val   halui.feed-override.direct-value     net  pdnt.halui.feed-override.counts       whb.halui.feed-override.counts       halui.feed-override.counts     #net  pdnt.halui.feed-override.count-enable whb.halui.feed-override.count-enable halui.feed-override.count-enable     #net  pdnt.halui.feed-override.value        halui.feed-override.value            whb.halui.feed-override.value     #setp                                       whb.halui.feed-override.min-value    [DISPLAY]MIN_FEED_OVERRIDE     #setp                                       whb.halui.feed-override.max-value    [DISPLAY]MAX_FEED_OVERRIDE     # min/max override depends on [DISPLAY]MIN_FEED_OVERRIDE and [DISPLAY]MAX_FEED_OVERRIDE     net  pdnt.halui.feed-override.increase   whb.halui.feed-override.increase   halui.feed-override.increase     net  pdnt.halui.feed-override.decrease   whb.halui.feed-override.decrease   halui.feed-override.decrease     #net  pdnt.button.feed-plus               whb.button.feed-plus     #net  pdnt.button.feed-minus              whb.button.feed-minus               # For printing the speed F:xxxx on display, the motion.current-vel velocity is used.     net  pdnt.motion.current-vel             motion.current-vel                 whb.motion.current-vel     # Connect axis position related signals     net  pdnt.halui.axis.0.pos-feedback      halui.axis.x.pos-feedback          whb.halui.axis.0.pos-feedback     net  pdnt.halui.axis.1.pos-feedback      halui.axis.y.pos-feedback          whb.halui.axis.1.pos-feedback     net  pdnt.halui.axis.2.pos-feedback      halui.axis.z.pos-feedback          whb.halui.axis.2.pos-feedback     net  pdnt.halui.axis.3.pos-feedback      halui.axis.a.pos-feedback          whb.halui.axis.3.pos-feedback     net  pdnt.halui.axis.5.pos-feedback      halui.axis.c.pos-feedback          whb.halui.axis.5.pos-feedback     net  pdnt.halui.axis.0.pos-relative      halui.axis.x.pos-relative          whb.halui.axis.0.pos-relative     net  pdnt.halui.axis.1.pos-relative      halui.axis.y.pos-relative          whb.halui.axis.1.pos-relative     net  pdnt.halui.axis.2.pos-relative      halui.axis.z.pos-relative          whb.halui.axis.2.pos-relative     net  pdnt.halui.axis.3.pos-relative      halui.axis.a.pos-relative          whb.halui.axis.3.pos-relative     net  pdnt.halui.axis.5.pos-relative      halui.axis.c.pos-relative          whb.halui.axis.5.pos-relative
Last edit: 4 years 4 months ago by mittim.
4 years 4 months ago #244603 by mittim
# Erstellt von PNCconf am Sat May 21 09:49:44 2022 # Using LinuxCNC version:  Master (2.9) # Änderungen an dieser Datei werden beim nächsten # overwritten when you run PNCconf again [EMC] MACHINE = test_2 DEBUG = 0 VERSION = 1.1 [DISPLAY] DISPLAY = axis POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 3.000000 MAX_SPINDLE_OVERRIDE = 2.000000 MIN_SPINDLE_OVERRIDE = 0.300000 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/timcnc/linuxcnc/nc_files INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm 1deg 1 2 5 10 45 90 180 360 POSITION_FEEDBACK = ACTUAL DEFAULT_LINEAR_VELOCITY = 6.000000 MAX_LINEAR_VELOCITY = 25.000000 MIN_LINEAR_VELOCITY = 0.500000 DEFAULT_ANGULAR_VELOCITY = 12.000000 MAX_ANGULAR_VELOCITY = 180.000000 MIN_ANGULAR_VELOCITY = 1.666667 EDITOR = gedit GEOMETRY = xyzac CYCLE_TIME = 100 PYVCP = spindle.xml [FILTER] PROGRAM_EXTENSION = .png,.gif,.jpg Greyscale Depth Image PROGRAM_EXTENSION = .py Python Script png = image-to-gcode gif = image-to-gcode jpg = image-to-gcode py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 SERVO_PERIOD = 1000000 [HMOT] # **** This is for info only **** CARD0=hm2_7i95.0 [HAL] HALUI = halui HALFILE = test_2.hal HALFILE = custom.hal POSTGUI_HALFILE = postgui_call_list.hal SHUTDOWN = shutdown.hal POSTGUI_HALFILE = spindle_to_pyvcp.hal [HALUI] [KINS] JOINTS = 6 KINEMATICS = xyzac-trt-kins coordinates=XYZACY [TRAJ] COORDINATES =  xyzacy   MAX_ANGULAR_VELOCITY = 360.00 DEFAULT_ANGULAR_VELOCITY = 36.00 LINEAR_UNITS = mm ANGULAR_UNITS = degree DEFAULT_LINEAR_VELOCITY = 2.50 MAX_LINEAR_VELOCITY = 25.00 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl #****************************************** [AXIS_X] MAX_VELOCITY = 25.0 MAX_ACCELERATION = 300.0 MIN_LIMIT = -140 MAX_LIMIT = 90 [JOINT_0] TYPE = LINEAR HOME = 0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 300.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 50 STEPGEN_MAXACCEL = 500 P = 1000 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 # these are in nanoseconds DIRSETUP   = 10000 DIRHOLD    = 10000 STEPLEN    = 5000 STEPSPACE  = 5000 STEP_SCALE = 800 MIN_LIMIT = -140.01 MAX_LIMIT = 90.01 HOME_OFFSET = -140 HOME_SEARCH_VEL = -10 HOME_LATCH_VEL = -0.1 USE_HOME_INDEX = NO HOME_SEQUENCE = 2 HOME_IGNORE_LIMITS = YES HOME_FINAL_VEL = 10 #****************************************** #****************************************** [AXIS_Y] MAX_VELOCITY = 25.0 MAX_ACCELERATION = 250.0 MIN_LIMIT = -100.01 MAX_LIMIT = 100.01 [JOINT_1] #LINKER MOTOR TYPE = LINEAR HOME = 0.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 250.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 31.25 STEPGEN_MAXACCEL = 350 P = 1000 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 # these are in nanoseconds DIRSETUP   = 10000 DIRHOLD    = 10000 STEPLEN    = 5000 STEPSPACE  = 5000 STEP_SCALE = 800 MIN_LIMIT = -100.01 MAX_LIMIT = 100.01 HOME_OFFSET = -125 HOME_SEARCH_VEL = -5 HOME_LATCH_VEL = -0.1 USE_HOME_INDEX = NO HOME_SEQUENCE = -3 HOME_IGNORE_LIMITS = YES HOME_FINAL_VEL = 5 [JOINT_5] #RECHTER MOTOR TYPE = LINEAR HOME = 0.0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 250.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 31.25 STEPGEN_MAXACCEL = 350 P = 1000 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 # these are in nanoseconds DIRSETUP   = 10000 DIRHOLD    = 10000 STEPLEN JOINT_5   = 5000 STEPSPACE  = 5000 STEP_SCALE = 800 MIN_LIMIT = -100.01 MAX_LIMIT = 100.01 HOME_OFFSET = -125 HOME_SEARCH_VEL = -5 HOME_LATCH_VEL = -0.1 USE_HOME_INDEX = NO HOME_SEQUENCE = -3 HOME_IGNORE_LIMITS = YES HOME_FINAL_VEL = 5 #****************************************** #*******JOINT_5*********************************** [AXIS_Z] MAX_VELOCITY = 25.0 MAX_ACCELERATION = 300 MIN_LIMIT = -140.01 MAX_LIMIT = 100.01 [JOINT_2] TYPE = LINEAR HOME = 0 FERROR = 10.0 MIN_FERROR = 1.0 MAX_VELOCITY = 25.0 MAX_ACCELERATION = 300.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 40 STEPGEN_MAXACCEL = 500 P = 1000 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 # these are in nanoseconds DIRSETUP   = 10000 DIRHOLD    = 10000 STEPLEN    = 5000 STEPSPACE  = 5000 STEP_SCALE = 800 MIN_LIMIT = -140.01 MAX_LIMIT = 100.01 HOME_OFFSET = 125 HOME_SEARCH_VEL = 5 HOME_LATCH_VEL = 0.1 USE_HOME_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_IS_SHARED = 0 HOME_FINAL_VEL = -1 HOME_SEQUENCE = 1 #****************************************** #****************************************** [AXIS_A] MAX_VELOCITY = 10.0 MAX_ACCELERATION = 30.0 MIN_LIMIT = -5 MAX_LIMIT = 92.5 [JOINT_3] TYPE = ANGULAR HOME = 0 FERROR = 0.5 MIN_FERROR = 0.05 MAX_VELOCITY = 10.0 MAX_ACCELERATION = 30.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 50 STEPGEN_MAXACCEL = 40 P = 1000 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 # these are in nanoseconds DIRSETUP   = 10000 DIRHOLD    = 10000 STEPLEN    = 5000 STEPSPACE  = 5000 STEP_SCALE = -888.8889 #-2222.2222222222222222 MIN_LIMIT = -5 MAX_LIMIT = 92.5 HOME_OFFSET = -6.815 HOME_SEARCH_VEL = -1 HOME_LATCH_VEL = -0.1 USE_HOME_INDEX = NO HOME_IGNORE_LIMITS = YES HOME_IS_SHARED = 0 HOME_SEQUENCE = 4 HOME_FINAL_VEL = 1 #****************************************** #****************************************** [AXIS_C] MAX_VELOCITY = 36.0 MAX_ACCELERATION = 100.0 MIN_LIMIT = -9999.01 MAX_LIMIT = 9999.01 [JOINT_4] TYPE = ANGULAR HOME = 0.0 FERROR = 1 MIN_FERROR = 0.15 MAX_VELOCITY = 36.0 MAX_ACCELERATION = 200.0 # The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION # If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger. STEPGEN_MAXVEL = 45 STEPGEN_MAXACCEL = 300 P = 2.2 I = 0 D = 0 FF0 = 0 FF1 = 1 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 0 ENCODER_SCALE = -555.5556 # these are in nanoseconds DIRSETUP   = 10000 DIRHOLD    = 10000 STEPLEN    = 5000 STEPSPACE  = 5000 STEP_SCALE = 1818.182 #1817.487868268479 MIN_LIMIT = -9999.01 MAX_LIMIT = 9999.01 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0 HOME_LATCH_VEL = 0 USE_HOME_INDEX = NO HOME_SEQUENCE = 5 #****************************************** [SPINDLE_0] P = 0 I = 0 D = 0 FF0 = 1 FF1 = 0 FF2 = 0 BIAS = 0 DEADBAND = 0 MAX_OUTPUT = 2000
4 years 4 months ago #244633 by mittim
It looks like my LinuxCNC 2.9 Version is too old to support duplicate digits. I will have to upgrade.
4 years 4 months ago - 4 years 4 months ago #244637 by jurod
You need the 5th axis as the W axis.
joint 6 must be a tandem axis as the Y2 or X2 axis.
The W axis is the depth into the material.
Last edit: 4 years 4 months ago by jurod.
4 years 4 months ago #244638 by mittim
Isn´t the W axis for a head-head configuration? I have a table-table configuration.
Time to create page: 0.107 seconds
