TCP 5-axis kinematics
4 years 4 months ago #245564 by andypugh
Replied by andypugh on topic TCP 5-axis kinematics
No, trivkins has no idea about those offsets and does not create those pins.
4 years 4 months ago #245656 by mittim
Replied by mittim on topic TCP 5-axis kinematics
Is there an existing kinematics module, which takes these two offsets into account without using TCP?
4 years 4 months ago #245741 by andypugh
What would you expect them to do in a trivial kinematics?
I am only guessing what it is that you want to do, but possibly you could modify your HOME_OFFSET in the INI to put the absolute origin in the centre, then you could have zero offsets in the TCP kins and the trivkins origin would match.
Or, you could add an offset to a custom version of trivkins.
4 years 4 months ago - 4 years 4 months ago #245763 by mittim
I have an offset of Dy in my machine, as shown in the picture. I want to compensate that with the Dy offset, which is usable in xyzac-trt-kins. So, in some way, I want to compensate the mismatch between axis C and Axis A, as they do not intersect each other, but without using inverse kinematics such as trt-kins.
I want to use forward kinematics such as trivkins and compensate my mechanical error. I have an xyzac machine. So, when rotating A, Z and Y would have to compensate the tip of the tool. Just like it is already implemented in trt-kins.
Last edit: 4 years 4 months ago by mittim.
4 years 4 months ago #245765 by andypugh
How is this different from using work offsets or tool offsets?
4 years 4 months ago #245767 by mittim
Maybe I have a wrong understanding of work offsets, but to my understanding, work offsets are not able to compensate for not intersecting axis of A and C. I made a sketch, that maybe helps understanding my problem.
In this simple example: For the tool being able to mill each side, it has to compensate its length according to the position of the A axis. Just like trt-kinematics is already doing when staying at XYZAC=0,0,0,0,0. I want to use this feature in simple forward kinematics.
I am not all too familiar with the code behind the kinematic modules, but to my understanding, X would just stay the same and every entry in Y and Z, which takes the rotation of C into account, could be ignored.
