need bitfile for 7i80hd + 7i52s + 7i44 + 7i73
11 Nov 2018 08:54 #120443 by 3D-Master
Hello,
i have a 7i80hd-16 7i52s 7i44 and 7i73 but i havent found a suiting bitfile so if anyone has a bitfile please share if possible.
if not i may need a custom bitfile but i am not remotely able to create one.
my needs are:
7 pwmgens and encoders for servos (5 of them are axis, one is the spindle and one is a toolchanger motor which is connected to the 7i73), all motors have an encoder (a,b,z ttl 5v) and are controlled with pwm and dir.
is there anything more i have to specify like in/outputs?
basically the 752s is connected to the port 1 on the 7i80hd, the 7i44 is connected to port 2 of the 7i80hd and the 7i73 is connected to the 7i44
thanks for any help
11 Nov 2018 09:47 #120445 by PCW
6 Axis of PWM/DIR is ok for a 7I52S but where is PWM/DIR7 connected?
11 Nov 2018 10:17 #120446 by 3D-Master
Replied by 3D-Master on topic need bitfile for 7i80hd + 7i52s + 7i44 + 7i73
cant i use the outputs of the 7i73 for that?
11 Nov 2018 11:09 #120447 by PCW
You can use the 7I73s output bits for slow PWM (1 KHz base frequency or so 1% resolution would have a 10 Hz PWM frequency) but not high speed PWM
11 Nov 2018 11:19 #120449 by 3D-Master
would 500hz be possible or is it bound to 1%?
11 Nov 2018 11:36 #120450 by PCW
500 hz is possible but you only have 3 levels: 100%, 50% and 0%
11 Nov 2018 11:58 #120453 by 3D-Master
i am totally fine with 500hz because it its only a toolchanger motor so i guess it doesnt need highspeed pwm or encoder counting (it also wont have a high resolution encoder).
11 Nov 2018 14:49 - 11 Nov 2018 15:07 #120458 by PCW
freeby.mesanet.com/7i80hd_16_svss12_8.bit
7I52S on P1, and P2, 7I44 on P3
12 PWM/encoders available 8 sserial channels
Last edit: 11 Nov 2018 15:07 by PCW.
11 Nov 2018 15:04 #120459 by 3D-Master
Thank you but the link you have posted says not found :/
also how do i connect the 7i52s to both P1 and P2? Or do you mean i can connect a second 7i52S on P2 if i want to?
11 Nov 2018 15:09 #120460 by PCW
Try the link again, i had to remake the bitfile (I also assumed you have a 7I80HD-16)
And yes, there's a place for a second 7I52S on P2 but its can be ignored if not used
Time to create page: 0.233 seconds
