need bitfile for 7i80hd + 7i52s + 7i44 + 7i73
- 3D-Master
- Thank you received: 5
12 Mar 2020 10:05 #159880
by 3D-Master
Replied by 3D-Master on topic need bitfile for 7i80hd + 7i52s + 7i44 + 7i73
thank you very much!
- 3D-Master
12 Mar 2020 12:52 #159892
by 3D-Master
somehow mesaflash says no board found. I put W1 and W2 in the down position so the board should have the ip address 192.168.1.121.
i also put the W2 in the up position to use the EEPROM ip address, which should be 10.10.10.10 (at least thats what my hal file says) and added "--addr 10.10.10.10" to mesaflash but stil no board found, even though i can connect to the board when starting the machine.
I have the feeling i forgot something but i cant find what is missing.
- 3D-Master
12 Mar 2020 12:57 #159893
by 3D-Master
if W1 is down and W2 is up, i can ping 10.10.10.10
- Thank you received: 5337
12 Mar 2020 12:58 #159894
Replied by PCW on topic need bitfile for 7i80hd + 7i52s + 7i44 + 7i73
Did you power cycle the card after changing the jumper?
also I would try pinging the card before running mesaflash
- 3D-Master
12 Mar 2020 13:00 #159896
by 3D-Master
yes i powered everything off, then switched the jumper and then powered everything up again
12 Mar 2020 13:08 #159898
OK normally you should not change the board IP address on a working configuration
because you would also need to change the host IP address settings, that is, you
should use whatever settings you currently use with LinuxCNC
If you use 192.168.1.121
mesaflash --device 7i80
should find the card
if you use 10.10.10.10
mesaflash --device 7i80 --addr 10.10.10.10
- 3D-Master
12 Mar 2020 13:17 #159901
by 3D-Master
i made a stupid mistake. I wrote:
sudo mesaflash --device 7i80 --addr 10.10.10.10-- fallback --write <bitfile name>.bit
i added a space and now i was able to flash it
thanks anyways
thanks anyways
- 3D-Master
12 Mar 2020 14:19 #159913
by 3D-Master
hmm. Now Linuxcnc says gpio.000.is_output not found
that was working before. In my Hal file is:
setp hm2_7i80.0.gpio.000.is_output true
setp hm2_7i80.0.gpio.023.is_output true
setp hm2_7i80.0.gpio.000.out false
setp hm2_7i80.0.gpio.023.out false
when i comment these out Linuxcnc starts but doesnt seem to output a PWM signal.
from Mesaflash --readhmid
sudo mesaflash --device 7i80 --addr 10.10.10.10 --readhmid
Configuration Name: HOSTMOT2
BoardName : MESA7I80
FPGA Size: 16 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 24
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 6 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: PWM
There are 6 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 1 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P1
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort PWM 0 /Enable (Out)
3 1 IOPort MuxedQCount 0 MuxQ-A (In)
5 2 IOPort MuxedQCount 0 MuxQ-B (In)
7 3 IOPort MuxedQCount 0 MuxQ-IDX (In)
9 4 IOPort MuxedQCount 1 MuxQ-A (In)
11 5 IOPort MuxedQCount 1 MuxQ-B (In)
13 6 IOPort MuxedQCount 1 MuxQ-IDX (In)
15 7 IOPort MuxedQCount 2 MuxQ-A (In)
17 8 IOPort MuxedQCount 2 MuxQ-B (In)
19 9 IOPort MuxedQCount 2 MuxQ-IDX (In)
21 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
23 11 IOPort PWM 0 PWM (Out)
25 12 IOPort PWM 0 Dir (Out)
27 13 IOPort PWM 1 PWM (Out)
29 14 IOPort PWM 1 Dir (Out)
31 15 IOPort PWM 2 PWM (Out)
33 16 IOPort PWM 2 Dir (Out)
35 17 IOPort PWM 3 PWM (Out)
37 18 IOPort PWM 3 Dir (Out)
39 19 IOPort PWM 4 PWM (Out)
41 20 IOPort PWM 4 Dir (Out)
43 21 IOPort StepGen 0 Step/Table1 (Out)
45 22 IOPort StepGen 0 Dir/Table2 (Out)
47 23 IOPort PWM 0 /Enable (Out)
IO Connections for P2
1 24 IOPort None
3 25 IOPort None
5 26 IOPort None
7 27 IOPort None
9 28 IOPort None
11 29 IOPort None
13 30 IOPort None
15 31 IOPort None
17 32 IOPort None
19 33 IOPort None
21 34 IOPort None
23 35 IOPort None
25 36 IOPort None
27 37 IOPort None
29 38 IOPort None
31 39 IOPort None
33 40 IOPort None
35 41 IOPort None
37 42 IOPort None
39 43 IOPort None
41 44 IOPort None
43 45 IOPort None
45 46 IOPort None
47 47 IOPort None
IO Connections for P3
1 48 IOPort SSerial 0 RXData1 (In)
3 49 IOPort SSerial 0 RXData2 (In)
5 50 IOPort SSerial 0 RXData3 (In)
7 51 IOPort SSerial 0 RXData4 (In)
9 52 IOPort SSerial 0 TXData1 (Out)
11 53 IOPort SSerial 0 TXEn1 (Out)
13 54 IOPort SSerial 0 TXData2 (Out)
15 55 IOPort SSerial 0 TXEn2 (Out)
17 56 IOPort SSerial 0 TXData3 (Out)
19 57 IOPort SSerial 0 TXEn3 (Out)
21 58 IOPort SSerial 0 TXData4 (Out)
23 59 IOPort SSerial 0 TXEn4 (Out)
25 60 IOPort SSerial 0 RXData5 (In)
27 61 IOPort SSerial 0 RXData6 (In)
29 62 IOPort SSerial 0 RXData7 (In)
31 63 IOPort SSerial 0 RXData8 (In)
33 64 IOPort SSerial 0 TXData5 (Out)
35 65 IOPort SSerial 0 TXEn5 (Out)
37 66 IOPort SSerial 0 TXData6 (Out)
39 67 IOPort SSerial 0 TXEn6 (Out)
41 68 IOPort SSerial 0 TXData7 (Out)
43 69 IOPort SSerial 0 TXEn7 (Out)
45 70 IOPort SSerial 0 TXData8 (Out)
47 71 IOPort SSerial 0 TXEn8 (Out)Please Log in or Create an account to join the conversation.
12 Mar 2020 14:22 #159916
I think those pins are controlled by the PWM enables
- 3D-Master
12 Mar 2020 14:26 #159917
by 3D-Master
i might reflash the old bitfile to see what has changed. i think i remember that the order of the pwmgens changed but im not sure.
Anyways when i want to home the servos nothing happens and linuxcnc goes into estop saying following error too high. i tried connecting the pwm/dir connector to the other comm ports to see if they are somehow swapped but no difference.
Time to create page: 0.193 seconds
