need bitfile for 7i80hd + 7i52s + 7i44 + 7i73
11 Nov 2018 15:14 #120461 by 3D-Master
Replied by 3D-Master on topic need bitfile for 7i80hd + 7i52s + 7i44 + 7i73
Thank you very much!
one step closer to my final machine :)
11 Nov 2018 15:22 #120462 by 3D-Master
okay while trying to flash the bitfile in the fallback eeprom i got an error:
error: wrong bitfile destination device: 6slx9ftg256, should be 6slx16ftg256
11 Nov 2018 16:33 #120465 by PCW
try refetching it, it should be fixed.
My build scripts at home were not synced to the up-to-date source so I had to futtz around a lot and busted some things
The following user(s) said Thank You: 3D-Master
11 Nov 2018 16:51 #120468 by 3D-Master
okay thank you now i was able to flash properly.
again Thank you!
12 Nov 2018 11:11 #120498 by 3D-Master
i am having trouble finding the correct Pins (a,b,z,pwm,dir,5v and gnd) on the boards. The manual says "the pins are like this but keep in mind it depends on FPGA configuration" and since i have a different bitfile flashed i dont think those pins are correct. Also HAL show doesnt give me the information i need. i would need a picture of the card with numbers on the hardware pins and HAL show say which pin functions are on which pin number.
13 Nov 2018 10:52 #120575 by 3D-Master
okay found the problem, i had to switch the jumpers from down to up on the encoder ports
11 Mar 2020 13:25 #159792 by 3D-Master
okay this thread is a bit old but i need one stepgen for testing. Maybe someone could modify the Bitfile for me?
Thanks in advance
11 Mar 2020 13:48 #159794 by PCW
Are you using 1 or 2 7I52s?
Where does the stepgen go?
(which PWM channel does it replace)
11 Mar 2020 14:21 #159798 by 3D-Master
i am currently using one 7i52s which is connected to P1 and would like the stepgen to replace channel 6 (...pwmgen.05...).
11 Mar 2020 18:55 #159830 by PCW
Time to create page: 0.772 seconds
