Kinematics and Delta Robot
20 Feb 2020 14:16 #158058 by barisduzenli
Replied by barisduzenli on topic Kinematics and Delta Robot
Hello Tommy,
Savaal, teshekyr, abey !
Was that correct ?
No. But when you say abey! We are laughing loudly in office. Now we are calling each other as abeyyy!! XD
20 Feb 2020 14:56 #158063 by barisduzenli
For multicore machines I have found big benefits in isolating the last cpu core for realtime events.
Look into ISOLCPUS for the realtime kernel.
at the command line run:
$ sudo nano /etc/default/grub
Find the line GRUB_CMDLINE_LINUX="" and update it to:
GRUB_CMDLINE_LINUX="isolcpus=1" (where 1 is the highest CPU core, dual core = 1, quad core = 3, etc)
then run:
$ sudo update-grub
and reboot, your RT jitter times should decrease
Thank you Sockheaven. Exactly, I will try tomorrow.
And, my scaling problem is continuing. I do not understand scaling or specify basic gear ratio. Not only in rotarydeltakins but also trivial kinematics.
21 Feb 2020 05:17 #158112 by barisduzenli
Hi Sockheaven,
Now I get servothread max jitter 24000 and base thread max jitter 36000.
Thank you.
  • Moderator
  • Moderator
21 Feb 2020 06:05 #158127 by tommylight
Replied by tommylight on topic Kinematics and Delta Robot
Nice ! :)
09 Apr 2020 07:12 #163323 by barisduzenli
Hello Tommy I have some problems that could not solve during a long time. Could you suggest somebody in Turkey that professionally assist us?
  • Moderator
  • Moderator
09 Apr 2020 18:48 #163409 by tommylight
There is another user here on the forum from Turkey, so might want to chat with him, but it is hard to find it here since i do not recal his user name.
What problems ?
16 Jul 2024 07:35 #305345 by faradaygv
Replied by faradaygv on topic Kinematics and Delta Robot
Buyurun Bizler Türkiye 'den Nokta CNC
Time to create page: 0.129 seconds
