Orient component revised
02 Apr 2020 22:33 #162503 by alkabal
Replied by alkabal on topic Orient component
Well,
Yes i actually use a muxed signal for enable the drive and the same connected to pendant for spindle status.
Mostly regarding the HAL status with orient activated the built in "halui.spindle.0.on" "spindle.0.on" seem to be strange to see as False.
If you think all is ok as it is : i understand and other connection is possible.
Br
02 Apr 2020 22:47 #162509 by andypugh
Replied by andypugh on topic Orient component
I can see that you might expect M19 to set spindle-on, but it seems that it doesn't. It's one of those things that could be argued either way.
In fact spindle-on only goes true after M3 / M4 _and_ when S > 0
03 Apr 2020 02:59 #162526 by alkabal
This is the reason for my message, i'm really unsure but in my opinion this need to be done for possible safety issue.
Unfortunately i haven't many arguments and i'm sure your decision was the good one regarding to this.
Br
05 Apr 2020 00:46 - 06 Apr 2020 02:42 #162733 by alkabal
First attempt for add a MPG/pendant jog mode
ultra basic send counts value to asked angle without checking the scale (more work is needed)
Not fully tested but i'm open for any suggestion.
If someone using the original component can test this one for feedback it be marvellous !
Br
Last edit: 06 Apr 2020 02:42 by alkabal.
06 Apr 2020 02:40 - 06 Apr 2020 02:43 #162832 by alkabal
Hi
Now jog mode use scale :)
TODO better management for enable spindle from pendant
Last edit: 06 Apr 2020 02:43 by alkabal.
09 Apr 2020 00:00 #163256 by alkabal
Well i really like testing from experimented user !
I have now do auto homing orient by index-enable automatically after machine is homed, or at first M19, or at first M3/M4
Jog work but is not perfect, i need to found a way for prevent moving if wheel is rotated before spindle homing and you do homing and enable_from_jog is already actived or later .
I have add some pin for display text message using link to MDI_COMMAND, but maybee they are better way to do this.
15 Apr 2020 00:42 #163996 by alkabal
15 Apr 2020 02:56 #164005 by cmorley
Replied by cmorley on topic Orient component
does this mean you must have the spindle rotating already to orient?
Another reason to not require S = 0 to turn off the spindle.
Chris
15 Apr 2020 08:26 #164030 by alkabal
Hi
The orient process is standalone, and do not use the traditional spindle hal signal.
But imo i think strange to not see spindle status on with "halui.spindle.0.on" "spindle.0.on" using orient
For now using orient yes S=0 but "halui.spindle.0.on" "spindle.0.on" = off
Br
15 Apr 2020 08:30 #164033 by cmorley
I think we should require that spindle be on to orient.
I don't think we should require the spindle to be spinning to have the spindle on.
I don't think we should require that the spindle be already spinning to orient.
Time to create page: 0.423 seconds
