Orient component revised
- alkabal
- Thank you received: 52
15 Apr 2020 11:07 #164051
by alkabal
1 : i think like you spindle=1 with S=0 and orient enable=1 is more clear
2 : i don't really know for other stuff but in my opinion if S=0 and orient=0 spindle-is-on need to be false
3 : ask M3/M4 S>0 when orient is enable = canceling orient and start spindle, the inverse is also ok so i think all is ok regarding to this. (not tested with M3/M4 S0)
Replied by alkabal on topic Orient component
I think we should require that spindle be on to orient.
I don't think we should require the spindle to be spinning to have the spindle on.
I don't think we should require that the spindle be already spinning to orient.
- Thank you received: 2181
15 Apr 2020 16:00 #164064
Replied by cmorley on topic Orient component
1)
I didn't say anything about the spindle number so I don't understand.
2)
Why do you think S=0 should automatically call a M5?
in my mind S sets the speed (speed includes 0)
M3/4/5 sets the state
3)
That seems fine.and I think already the default
2)
3)
- alkabal
15 Apr 2020 16:57 - 15 Apr 2020 17:23 #164066
by alkabal
1 sorry my message is not clear, i speak about S=0rpm and orient is enable i think strange to not see spindle.x.on=true (not speak about multi spindle).
2 yes i think with setting 0rpm and orient disabled imo is better to stop spindle completely.
i'm not an expert, maybee this is needed for some servo/stepper spindle but in this way i think this need to be the same with orient. (and allow to have a more easy hal config for orient)
3 yes it is
For orient i need to pass through the enable signal for spindle controler
If ask M19 allow to ask spindle.0.on this not be needed anymore, but removing input/output from component lock the possibility to force enable from jog mode so these change nothing.
3 yes it is
pin in bit enable_from_jog "enable angular output for orientation mode from pendant mpg jog";
pin out bit ena_out_muxed "enable muxed from orient or velocity or jog";
pin out bit ena_to_pid_orient "enable for Orient PID need to be separated from drive enable";
pin in bit ena_from_velocity "enable from velocity mode";
Last edit: 15 Apr 2020 17:23 by alkabal.
15 Apr 2020 17:20 #164067
Well I don't disagree. setting S to 0 should set the spindle to stop turning, but it shouldn't require m3/m4 to start it again, you should be able to set S to a positive number and it should turn. It's a subtle difference but useful and consistent ideology.
1
15 Apr 2020 18:52 #164072
using the new multispindle frame work i added an indexer to my mill.
I use the second spindle commands to operate at. the S command specifies the position in degrees. it works fine but if you specify S0 then the indexer is tuned off rather then move to 0 degrees. it also requires M3 to start again.
While I realize this is extending the spindle to unintended use - it works very well and is easy to add to a config. My discussion about S0 really comes down to it allows one to do more with linuxcnc and does not affect any standard gcode program out there. I don;t think it is usual for people to actually set S to 0, one would use M5
I'll have to look at your code and see if I could use it on my indexer. ultimately i would like to be able to select spindle mode and indexer mode.
Chris
Chris
- alkabal
15 Apr 2020 19:55 - 16 Apr 2020 01:54 #164080
by alkabal
Yes off course ii think like you : nobody use S0 for stop spindle.
I hope my code can work for your setup but i think need more work. you can use HAL exemple inside comp (need to add the pid setting)
Attached Orient pid pyvcp panel + last revision
I have do the test with 2.9
Start spindle from GUI or from M3/M4
set S0 (spindle stop moving, hal signal = false but Axis gui button stay pushed...)
Set S100 does not restart spindle, need to push GUI button again.
Well i think this is not really logic mostly regarding the GUI status.
Edited for last revsion
Last edit: 16 Apr 2020 01:54 by alkabal.
- alkabal
16 Apr 2020 01:54 #164101
by alkabal
now i understand why you want spindle on with S0, but it is better to have your setup or use a orient component ?
can i ask more about what you have do in your config ?
- giz
- Thank you received: 11
16 Apr 2020 15:48 #164161
by giz
Replied by giz on topic Orient component
I don't have anything to contribute, but I'm trying to follow this conversation. I've had a horrible time trying to program a working Orient on my machine.
16 Apr 2020 17:18 #164168
So My indexer is not going to work with you rorient component because it's stepper based.
My main spindle is a servo motor, but currently can only run i one direction.
I haven't had a chance to set up rour orient on my main spindle yet.
I did find where linuxcnc sets M5 when S=0, so i want to test that change too.
Chris
Chris
- alkabal
16 Apr 2020 17:43 - 16 Apr 2020 17:43 #164171
by alkabal
Hi i have see your topic some time ago when i try to setup original orient.comp but imo this component is really hard to setup correctly .
I like if you can check about this work in progress new comp i have do the most possible for allow easy setup.
copy past hal exemple from comp
add pid settings
remove 2 hal link from spindle setup and past to orient hal maybee adapt net link name for match your spindle net link name for this 2 link
first change :
#net spindle-enable => [HMOT](CARD0).7i83.0.0.analogena0 # moved in the orient input output
net spindle-enable => orient.orient-spindle.ena-from-velocity
net spindle-orient-enable-out => [HMOT](CARD0).7i83.0.0.analogena0 # moved in the orient input/output but initially in spindle setup
second change :
#net spindle-vel-cmd-out => [HMOT](CARD0).7i83.0.0.analogout0 # moved in the orient input output
net spindle-vel-cmd-out => orient.orient-spindle.cmd-from-pid-velocity
net spindle-orient-ctrl-out => [HMOT](CARD0).7i83.0.0.analogout0 # moved in the orient input/output but initially in spindle setup
Saad but this yes this component is do for regular motor.So My indexer is not going to work with you rorient component because it's stepper based.
Chris
add pid settings
first change :
second change :
Last edit: 16 Apr 2020 17:43 by alkabal.
Time to create page: 0.738 seconds
