implement 8-tool turret on lathe
5 years 2 months ago #216657 by RobotMatic
Thanks a lot!!!!.
I was reading the 2.7 documentation, I will leave it like that for now and I will update later !!!.
the X axis is fine !!. it's just visual.
I'm glad that 2.8.x has an easy solution
Thanks a lot  BigJognT - andypugh !!!!!!
5 years 2 months ago #216659 by joekline9
You can put in g code file:
G10 L2 P0 R180 (Rotate around Z axis, 180 for back tool, R0 for front)
I use front and back tools in the same program with gang tooling.
Although there is a bug in 2.8 that requires a work around.
The following user(s) said Thank You: RobotMatic
5 years 2 months ago #216695 by andypugh
Is that bug listed in the bug tracker?
5 years 2 months ago #216708 by RobotMatic
I already have the X axis working fine.
But I noticed that the  X JOG keys are reversed.
Can it be reversed? or do I have to change the direction of rotation of the motor?
Thank you!!
5 years 2 months ago #216716 by andypugh
Is it actually wrong? Jog + should move further away from the spindle axis.
5 years 2 months ago #216723 by RobotMatic
jog-X-reversed manual movement
the x-axis works perfect, the coordinate system is now well defined. only the manual movement of jog X was reversed
