implement 8-tool turret on lathe
5 years 2 months ago #216726 by RobotMatic
Axis and jog X coincide in their + and - signs.  But the X axis moves reversed and correct in its + and - signs.
They are dissociated, both are doing well but inverted between them
remember I am using 2.7.14. !! Should I update to 2.8.2? is this necessary to fix this problem?
I'm dizzy and I don't know if I'm doing something wrong
5 years 2 months ago #216729 by andypugh
Are you talking about jogging from the GUI, with buttons, or with an MPG?
5 years 2 months ago #216731 by RobotMatic
as shown in the video !!!. with the buttons on the pc keyboard
5 years 2 months ago #216740 by andypugh
Sorry, I hadn't noticed the video.
What you see is the default Axis jog directions, which make perfect sense with a front-tool lathe. And not with a back-tool (or even top tool) lathe.
You can swap the key bindings by creating a .axisrc file:
forum.linuxcnc.org/38-general-linuxcnc-q...jog-arrows-direction
5 years 2 months ago #216753 by RobotMatic
ready, there it was very good !.
Edit the file and remap the jog keys.
Thank you very much for so much support !!!!
now what is left for me to finish programming the turret !!!
linuxcnc is very great !!! I feel like I learn a little more every day !! But Linuxcnc expands like the universe !!!!.
again !! Thank you very much for so much support !!
        Nestor Eduardo Gonzalez ( RobotMatic ) from Argentina.
5 years 2 months ago - 5 years 2 months ago #216769 by joekline9
As I said before:
You can put in g code file:
G10 L2 P0 R180 (Rotate around Z axis, 180 for back tool, R0 for front)
I use front and back tools in the same program with gang tooling.
Although there is a bug in 2.8 that requires a work around. "
The bug is in the bug tracker.
I put:
[TRAJ]
COORDINATES = X Y Z
in the ini file. It displays a fake Y axis but makes it work OK.
Last edit: 5 years 2 months ago by joekline9. Reason: Clearify
Time to create page: 0.632 seconds
