Mitsubishi VFD Modbus cant get it work
11 Jan 2022 15:40 #231487 by hitchhiker
Replied by hitchhiker on topic Mitsubishi VFD Modbus cant get it work
Hi dudes....
i am in struggle and stress to get my vfd work...
after day work arround i get this error:
from terminal is send:
halcmd loadusr mitsub_vfd --baud 9600 --port /dev/ttyUSB0 spindle=01
get :
cnc@cnc:~$ /dev/ttyUSB0 9600
ERROR : mitsub_vfd - No serial interface found at /dev/ttyUSB0
i am with user cnc in the dialout goup...
its a ch341 usb rs232 to rs485 adapter.
adapter and vfd works with mach3.
i load the mitsub_vfd.py form :
github.com/LinuxCNC/linuxcnc/blob/2.8/sr..._comps/mitsub_vfd.py
then i halcompile --install mitsub_vfd.py over the terminal.
i checked that ttyusb1 is correct via sudo dmesg | grep tty.
what can i do? thanks
11 Jan 2022 16:42 #231496 by andypugh
Replied by andypugh on topic Mitsubishi VFD Modbus cant get it work
ttyUSB0 or ttyUSB1?
Does it appear and disappear when you plug and unplug?
11 Jan 2022 20:02 #231512 by cmorley
Replied by cmorley on topic Mitsubishi VFD Modbus cant get it work
Please stop asking help with this problem in multiple places.
11 Jan 2022 20:16 #231514 by cmorley
Don't follow that link for this problem.
What distribution do you use? Mint?
Did you use proper case of the port?
ie. ttyUSB0 not ttyusb0?
12 Jan 2022 00:17 #231530 by hitchhiker
good morning
LinuxCNC 2.8.2 Debian 10 Buster RTAI
from usbstick.. i put in boot from usb install graphic mode..
when the first screen pops up its a linuxcnc live version
debian,yes and i checked all case szenario...
12 Jan 2022 02:15 #231535 by cmorley
You haven't installed linuxcnc on your computer?
Hmm i wonder if that affects the acess to the serial port.
please open a terminal and run the command:
ls -l /dev/ttyUSB0
and post the answer here.
  • ALittleOffTheRails
  • ALittleOffTheRails's Avatar
  • Visitor
  • Visitor
12 Jan 2022 02:47 #231538 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic Mitsubishi VFD Modbus cant get it work
Plug in the dongle
Unplug the dongle
Plug the dongle back in
sudo dmesg
The information regarding said dongle should appear at the end. Remember case in devnames does matter.
You will also need permissions to use the device.
12 Jan 2022 02:51 #231540 by hitchhiker
no no no.. it is intalled!
www.linuxcnc.org/iso/linuxcnc-2.8.2-buster.iso
this is the iso of my dvd/usbstick what i use to install linux debian together with linuxcnc..
after the install .. you start your computer and have linuxcnc ready.
one install process.
i think it is a minimal install.. because.. its a small image...
i read its the easy way to get linuxcnc.. but i think.. some parts are not included... possible?
thanks.
12 Jan 2022 02:54 #231541 by cmorley
Please try the instructions I asked you to.
12 Jan 2022 03:05 #231545 by tommylight
Replied by tommylight on topic Mitsubishi VFD Modbus cant get it work
Both topic merged.
Stop opening new topic for the same thing, @hitchhiker
Time to create page: 0.630 seconds
