Mitsubishi VFD Modbus cant get it work
- Thank you received: 2181
11 Jan 2022 00:52 #231406
Replied by cmorley on topic Mitsubishi VFD Modbus cant get it work
I don't know.
But here is the version you want:
github.com/LinuxCNC/linuxcnc/blob/2.8/sr..._comps/mitsub_vfd.py
- hitchhiker
11 Jan 2022 00:59 #231408
by hitchhiker
Replied by hitchhiker on topic Mitsubishi VFD Modbus cant get it work
ok. i give it in some hours a try.
how i can uninstall the loaded py3 mitsub_vfd?
if i have py 3.7 and the file from github... do i only need install or do i need more?! compile? dont know...
thanks
thanks
11 Jan 2022 01:28 #231410
py 3.7 is not used for linuxcnc 2.8
overwrite the py3 mits sub with the one I posted a link to.
Did you compile linuxcnc ?
- hitchhiker
11 Jan 2022 01:41 #231411
by hitchhiker
compile???i installed it from a iso ...
put in,boot, install.. to a complete empty hdd.
you mean delwte all mitsub_vdf files i can found and install the py2 version?
do i need halcompile -- install mitsub_vfd.py only or halcompile --compile?!
thanks for your help!!!
11 Jan 2022 08:06 #231443
yes delete the old mitsub add the py2 one.
tell me where you found it in your system.
I don't ever use an installed version so will need to check where it needs to go.
if it's in the right place you don't need to compile it.
- hitchhiker
11 Jan 2022 08:14 #231446
by hitchhiker
i found it not. i installed it from the download folder.
after this i found it in linuxcnc shared or something like this..
u understand?
u understand?
- hitchhiker
11 Jan 2022 09:07 #231451
by hitchhiker
is there a function to search a filename to the complete filesystem?
- hitchhiker
11 Jan 2022 10:39 #231458
by hitchhiker
intersting thing... i go to usr/bin and find the mitsub_vfd
this mitsub_vfd have python2 in first line and is 447 lines long.
the one you told me to install is 390 lines long....
- hitchhiker
11 Jan 2022 11:47 #231463
by hitchhiker
ok... now i got error...
no serial interface found at ttyusb0
its ch341.... sudo dmesg | grep tty shows me ch341-uart converter now attached to ttyusb0
solution???
its a big step to get this error..but why?!
solution???
- jpg
- Thank you received: 13
11 Jan 2022 12:44 #231467
by jpg
Replied by jpg on topic Mitsubishi VFD Modbus cant get it work
Hello, look at this link, I hope it could help you:
forum.linuxcnc.org/38-general-linuxcnc-q...-emc-please?start=40
Time to create page: 0.280 seconds
