Mitsubishi VFD Modbus cant get it work
- hitchhiker
- Thank you received: 21
12 Jan 2022 11:22 #231574
by hitchhiker
Replied by hitchhiker on topic Mitsubishi VFD Modbus cant get it work
~$ ls -l /dev/ttyUSB0
give me :
dialout correct or?!
crw-rw---- 1 root dialout 188, 0 Jan 12 17:54 /dev/ttyUSB0
give me :
- hitchhiker
12 Jan 2022 12:37 #231579
by hitchhiker
i done a test.... my friend use a hitachi vfd wj200.
i connect my pc,with the rs485 ch341 dongle to his wj200.
then i load his machine from my pc. the vfd works.
crosstest... its not possible to connect to the mitsub_vfd.
then we use a rs232 to rs485 adapter, nothing, same error. with his wj200 no problem.
then we use a ftdi 232 to 485.. same problem.
when i use terminal, run hal, loadusr mitsub_vfd, everytime i get error no serial interface found.
could it be a problem with python?!
or is the mitsub_vfd not working because it have a failure inside?!
for my understanding :
it must be possible to load the compnent inside the terminal right?
can someone please test it?
hal run
loadusr mitsub_vfd
thanks
hal run
loadusr mitsub_vfd
thanks
- Thank you received: 1482
12 Jan 2022 13:05 #231583
Replied by Todd Zuercher on topic Mitsubishi VFD Modbus cant get it work
Your Mitsubishi drive still works with Mach3?
My best guess is it is most likely a configuration issue with the RS485 com settings with the Mitsu drive.
Could you post copies of your Mach3 modbus config files, so we can compair them with the settings you're trying to use with Linuxcnc?
Should be files named something like "ModBus.cfg" or "TCPModBus.cfg".
- hitchhiker
12 Jan 2022 13:07 #231584
by hitchhiker
hey hey hey
i got it work!!!!
i founda simple solution, now i will test it.. if it works i post it!
i must make coffee and start what i think...
i got it work!!!!
12 Jan 2022 13:50 #231593
What was the problem?
- hitchhiker
12 Jan 2022 13:55 #231595
by hitchhiker
ok...
i add to the mitsub_vfd.py the line
self.ser.close()
befor
self.ser.open()
now i do:
terminal
halrun
loadusr -Wn test mitsub_vfd -p /dev/ttyUSB0 mitsu=01
but i cant get the vfd to run...
i show me the pins with show pin
then i send:
mitsu.run TRUE
mitsu.motor-cmd 100
nothing happend.
i will upload mach3 settings... i have found the modbus.cfg but in this file are only 2 and other symbols.
but i know my settings.
com2 9600 baud 2 stop none parity
slave adress 1
num reg is 1
start is as holding registers:
8 for start fwd (2), start rev, stop (0)
13 for speed
the brain :
spindle cw on pass signal A*2 mod:0-P:0
spinRPM -Ovden pass signal A/0.28 mod:0-P:1
should i upload this 2 files? or is this ok?
thanks
self.ser.close()
befor
self.ser.open()
now i do:
terminal
halrun
then i send:
mitsu.run TRUE
mitsu.motor-cmd 100
nothing happend.
slave adress 1
num reg is 1
13 for speed
the brain :
thanks
12 Jan 2022 14:20 #231601
Try starting Linuxcnc from the command line, then watch that terminal for error messages that might give a better clue to what the current problem is.
- hitchhiker
12 Jan 2022 14:22 #231603
by hitchhiker
this is whst i done for the first error ever i get on linux
i will check with oszi ifi have transfer between rs485 pc to rs485 mitsubishi vfd....
- Thank you received: 2181
12 Jan 2022 21:16 #231628
Replied by cmorley on topic Mitsubishi VFD Modbus cant get it work
try setting estop to true.
There is also a debug pin that will print lots of debug messages to the terminal
- hitchhiker
13 Jan 2022 00:14 #231630
by hitchhiker
good morning.
i try this, but .. nothing.
could it be a issue with the ch341 driver? i test it with a ftdi to max485.. nothing... on my mach3 both works.
the traffic with a real oszi show a little bit different between mach3 and linuxcnc....
dont know whats wrong....
Time to create page: 2.157 seconds
