Mitsubishi VFD Modbus cant get it work
13 Jan 2022 00:35 #231631 by hitchhiker
Replied by hitchhiker on topic Mitsubishi VFD Modbus cant get it work
one thing....
on my mach3 pc the ftdi usb dongle blinks...
on my linux pc... no blinking.
13 Jan 2022 07:19 #231657 by cmorley
Replied by cmorley on topic Mitsubishi VFD Modbus cant get it work
is this what you see (run from a terminal)
halrun
loadusr mitsub_vfd -p /dev/ttyUSB0
halcmd: /dev/ttyUSB0 9600
Mitsubishi VFD serial computer link has loaded
Port: /dev/ttyUSB0,
baudrate: 9600
8 data bits, no parity, 2 stop bits
Mitsubishi mitsub_vfd VFD: slave# 00 added
setp mitsub_vfd.debug 1
halcmd: setp mitsub_vfd.estop 1
halcmd: **** Mitsubishi VFD: Estop cleared - Must re-issue run command to start mitsub_vfd.
setp mitsub_vfd.run 1
halcmd: DEBUG:
setp mitsub_vfd.monitor 1
halcmd: DEBUG:
halcmd: DEBUG:
control c to exit
also the settings on the vfd for:
PR 79 - 1 or 0
# PR 117 station number - 1 (can be optionally set 0 - 31) if component is also set
# PR 118 communication speed 96 (can be optionally set 48,96,192) if component is also set
# PR 119 stop bit/data length - 0 8 bits, two stop (don't change)
# PR 120 parity - 0 no parity (don't change)
# PR 121 COM tries - 10 if 10 (maximuim) COM errors then inverter faults (can change)
# PR 122 COM check time interval 9999 (never check) if communication is lost inverter will not know (can change)
# PR 123 wait time - 9999 - no wait time is added to the serial data frame (don't change)
# PR 124 CR selection - 0 don't change
13 Jan 2022 07:46 #231659 by hitchhiker
in 3 hours i am baxk home.
when the slave adress is 00 i must change on the vfd to 00?
my vfd is 01
or can i give him a name like test=01 to get it as adress 01?
thanks
13 Jan 2022 07:53 #231660 by cmorley
Yes you can have any slave number between 0 - 31 if you specify it at load time.
test=01 is right
Have you looked at the docs?
linuxcnc.org/docs/2.8/html/man/man1/mitsub_vfd.1.html
13 Jan 2022 08:18 #231663 by hitchhiker
yes i looked to it
have you seen how i get the modul working? i post it yesterday
set serial close and then open?
have you a reason for this?
could it be a usb driver problem?!
i use ch341 232 to 485 via usb.
or ftdi 232 to 485 via usb.
i thank you so much
13 Jan 2022 11:09 #231680 by hitchhiker
i try what you wrote.
[ 5.968271] 0000:04:00.0: ttyS1 at I/O 0xd0c8 (irq = 18, base_baud = 115200) is a XR16850
[ 1394.753691] usb 2-10: ch341-uart converter now attached to ttyUSB0
cnc@cnc:~$ halrun
halcmd: loadusr test mitsub_vfd -p /dev/ttyUSB0 test=01
halcmd: test: zusätzliches Argument „-p“
halcmd: show pin
Component Pins:
Owner Type Dir Value Name
halcmd: loadusr -Wn test mitsub_vfd -p /dev/ttyUSB0 test=01
/dev/ttyUSB0 9600
Port: /dev/ttyUSB0,
baudrate: 9600
Mitsubishi test VFD: slave# 01 added
halcmd: setp test.debug 1
halcmd: setp test.estop 1
**** Mitsubishi VFD: Estop cleared - Must re-issue run command to start test.
halcmd: setp test.run 1
halcmd: DEBUG:
halcmd: setp test.monitor 1
halcmd: DEBUG:
DEBUG:
DEBUG:
DEBUG:
DEBUG:
DEBUG:
debug is empty.. shows not correct...
13 Jan 2022 13:47 #231700 by hitchhiker
i try to read to the tx line from ft232 to max485.
on mach3 2 leds blinks... rx and tx
with linux only the tx led blinks onetime when i send am command t the vfd like .run 1 or .run 0.
if i do this on mach3 rx tx blinks.
the traffic on mach 3 looks different to linuxcnc.
mach3 : working modbus,rx tx blinks, commands are clear to read as hex.
linuxcnc : only tx blinks when send a command, the command change everytime.
14 Jan 2022 17:16 #231815 by hitchhiker
today i done some test... i installed arduino ide and programm some arduinos with ch341 and ftdi232 ... no problems...
i think the problem is inside to code? could it possible?
thanks
14 Jan 2022 17:55 #231823 by cmorley
Sure it's possible - though I used the driver for my lathe.
Did you confirm the settings on the VFD?
14 Jan 2022 17:59 #231825 by hitchhiker
yes all settings are done.
i have the same settings for mach3.
do you use a rs232 with db9 or usb?
do you have it running or is it years ago???
thanks
Time to create page: 2.627 seconds
