Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
1 year 5 months ago - 1 year 5 months ago #327929 by jochen91
I exported it in STL and OBJ. I had problems getting Fusion STL export into vismach. OBJ worked flawless. Thank you!
Last edit: 1 year 5 months ago by jochen91.
1 year 5 months ago #327931 by meister
there are two versions of STL files, ASCII and Binary, you have a binary file and vismach can only read the ASCII format
1 year 5 months ago #327932 by Aciera
I'll try to open it in solidworks and reexport it as Ascii.
1 year 5 months ago #327936 by jochen91
In case it didn't work in solidworks here it is in ASCII format. In Fusion you have to take some extra steps to export it in ASCII format.
1 year 5 months ago #327938 by Aciera
Worked fine (had to scale it 10x).
This is the modified turning operation (which works in TCP mode now).
Warning: Spoiler!
Note the tilted b-axis to compensate for the chosen tool:
Alternatively the operator could also orient to tool spindle 180° (m19 r180) and run it with b0 and the work spindle turning in the opposite direction:
As already pointed out, the milling operation using 'G19' does not work:
Is there a way to change this to 'regular' G17 in the PP?
The following user(s) said Thank You: besriworld, jochen91
1 year 5 months ago #327942 by Aciera
Looking at this:
makes me wonder if you can get the CAM so use 'D0':
G368 X0. Z0. D0. B-45. W1
Instead of 'D1'
G368 X0. Z0. D1. B-45. W1
Time to create page: 0.205 seconds
