Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
1 year 5 months ago #328387 by Aciera
You have G54 offset active, which is set to Z: 180 so since the spindle nose is in the home position you get a z-position of -180.
The following user(s) said Thank You: jochen91
1 year 5 months ago #328395 by jochen91
But how is G54 active after homing and no G-code execution? I have two machines running LCNC (2.7.4) an both don't do that. That's confusing me a little bit.
RS274NGC_STARTUP_CODE = G17 G21 G40 G49 G64 P0.001 G80 G90 G92.1 G94 G97 G98 # G54
I commented the G54 out of the .ini File but the behavior does not change.
1 year 5 months ago #328397 by Aciera
Linuxcnc will save the work offset on shut down. Also G54 is the default offset system on startup. Since the example code contains ' g10 l2 p0 x0 y0 z180' the G54 z-offset is set to 180 which is then stored on shutdown and restored on restart.
As far as I know it has always restored the last offset values but I have only ever worked with Versions 2.8 or later.
1 year 5 months ago #328401 by jochen91
I figured it out now and could fix it.
There is one more thing. The key binding.
I found: forum.linuxcnc.org/21-axis/14675-keyboar...key-binding?start=20
and implemented the .py file. It works, but i want to use page up/down for the X axis. How should one know how the correct name/definition in the .py file has to be? Do you have an idea ?
Z and Y works.
1 year 5 months ago #328403 by Aciera
1 year 5 months ago #328541 by jochen91
Hello Aciera,
i spend more time with it and found one more challenge.
While working with TWP i saw a problem, that it does twist the workplane perfectly but it also changes the axis definition.
Z Integrex is becoming X (Conventional)
X Integrex is becoming Z (Conventional)
Y stays Y
While this behavior can be surely handled in the PP, its a bit of a mess in LCNC. Soft limits are fairly difficult to define and in AXIS GUI it also looks a bit messy. The Doosan PP also does not change Z/X definition, when G368 is posted. And of course the key binding is also off in TWP mode.
The question is now: Can G68 keep the original Integrex Axis definitions ?
Time to create page: 0.390 seconds
