- Configuring LinuxCNC
- Advanced Configuration
- Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
- jochen91
- Thank you received: 23
19 Jul 2025 09:46 #332021
by jochen91
Replied by jochen91 on topic Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
The following user(s) said Thank You: RotarySMP, besriworld
- jochen91
19 Jul 2025 09:47 - 19 Jul 2025 09:48 #332022
by jochen91
Last edit: 19 Jul 2025 09:48 by jochen91.
- jochen91
19 Jul 2025 09:54 - 19 Jul 2025 10:21 #332024
by jochen91
I wanna note: It looks kinda professionally done, but its not. I'm in the luck of having a father in law that owns the place (he is a mason by profession) and i can use the place and the incredible useful overhead crane. Without that it would be impossible. For other projects i used the good old engine hoist in my garage, but for this machine it is just to small.
I will update as soon as there is any progress done.
- Need to solve the guide rail problem
- Ways need to be reground and scraped. Including the gibs.
- Ballsrews need to be serviced
- Milling spindle needs to be repaired
- CLEANING
Last edit: 19 Jul 2025 10:21 by jochen91.
- Thank you received: 7505
19 Jul 2025 12:10 #332027
Replied by tommylight on topic Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Upload the pictures on the forum, not on 3rd party sites as they may (and will) contain mallware/tracking stuff.
Thank you.
I do have, new newer used THK rails sitting in the shop, namely:
2 of 780mm long 35mm wide rails with 4 of long and narrow carriages, roughly 150mm long
2 of 360mm long 30mm wide rails with 2 of short and narrow carriages
More info if you think you can use them, and might be able to ship to you at the end of August.
I do have 2 more of used THK45 rails and 2 carriages 1 long and short, rails one is 1250mm and the other should be around 700mm. Pretty rough condition but no play.
Thank you.
- jochen91
20 Jul 2025 03:38 - 20 Jul 2025 03:47 #332049
by jochen91
I tried replacing the image links with uploaded files directly but i does not work.
Even files way smaller then 1.6Mb ( 1.1MB) the forum complains its to big. So I'm open for suggestions.
For the Rails: They are from the THK NRS Series. Size 35mm and 44mm overall height (Non standard)
Preload C0
5 x LRX carriages
1 x LR carriages
Also the bolt pattern is a little bit odd. See Datasheet attached. If, by any change, you have this exact model, I'm definitely open for negotiations
Preload C0
5 x LRX carriages
1 x LR carriages
Last edit: 20 Jul 2025 03:47 by jochen91.
20 Jul 2025 12:34 #332072
I do not think any of mine are 44mm in height, should be more, but i will have to check that to be sure.
I will also check the exact model, if possible.
- jochen91
21 Jul 2025 05:09 #332108
by jochen91
I got bad news from the spindle repair shop. They gave me an estimated quote of 8-10k€,,, thats a little bit to much. I think I need do it on my own.
Need to watch some Robin Renzetti videos to get in the mood to touch that thing
My plan is to replace the bearings on my own and than search for a service provider, that can regrind the taper on the machine.
- jochen91
29 Dec 2025 07:12 #340654
by jochen91
Hi Folks,
im still living. Wanna give you a status update:
Jochen
- The spindle taper is fixed (Needed to be Laserwelded and reground)
- New spindle bearings
- I scraped the geometry of the Y axis. Which was a major step, and im not satisfied with the bearing points. (Geometry is excellent) When it gets warmer in Germany i want the moglice all the guide ways. Epoxy is already ordered.
- I reassembled the B axis. In january i hope to reassemble the spindle and mount it to the B axis. I need the spindle and B axis ready and mounted to the X axis slide to check and scrape (even for moglice scraping is needed) the geometry.
Jochen
- Thank you received: 2177
29 Dec 2025 07:26 - 29 Dec 2025 09:59 #340655
Replied by Aciera on topic Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Good to hear that you are making progress.
[edit]
I would be interested to know how tool offsets are handled in the tool table for lathe tooling in the milling spindle on such a mill-turn machine. On a lathe the tool offset is different to a mill in the sense that the length of the tool is an X-offset as opposed to a Z-offset. That is why I have made two different TCP (mill / lathe) modes in this sample config. I wonder if that is actually necessary or if lathe tool offsets are handled just like milling tools.
[edit]
Last edit: 29 Dec 2025 09:59 by Aciera.
- jochen91
01 Jan 2026 11:32 #340845
by jochen91
I will definitly check that, when the machine is back together. At the moment i cant power on the machine because most of the wires are disconnected.
Time to create page: 0.171 seconds
