- Configuring LinuxCNC
- Advanced Configuration
- Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
- Thank you received: 2176
16 May 2025 15:18 #328576
Replied by Aciera on topic Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
- You need to mark the files 'M128' and 'M129' as executable (rightclick-> Properties -> Permissions).
I don't know about changing the key binding at run time but I would strongly advise against using keybord bindings to jog the actual machine. Much better to use hardware panel buttons connected to realtime hardware inputs.
Not sure what you mean by 'executing' a custom component. A 'custom component' refers to something that runs in HAL and as such runs periodically.
linuxcnc.org/docs/html/hal/comp.html
Do you maybe mean a 'remap' to create/redefine a g- or m-code?
- jochen91
- Thank you received: 23
21 Jun 2025 06:09 - 20 Jul 2025 08:20 #330614
by jochen91
Replied by jochen91 on topic Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
Hello,
im sorry for being a long time without news.
I bought the Machine and transported it to my location. At the moment I am trying to make everything work under the old Fusion640MT control.
Sadly i realized, that the milling spindle seen better times. Runout is quite high, and the bearings sound not good. I'm in the process of getting it fixed.
After i checked as many functions as i can with the old control, i will start the retrofit. The questions i have for now:
Shall i continue this thread or open a new one in the right subforum for the retrofit itself ?
Last edit: 20 Jul 2025 08:20 by jochen91.
- jochen91
21 Jun 2025 06:14 #330615
by jochen91
- jochen91
21 Jun 2025 06:23 - 21 Jun 2025 06:24 #330617
by jochen91
And finally a tiny video:
Last edit: 21 Jun 2025 06:24 by jochen91.
The following user(s) said Thank You: besriworld, Aciera
- dm17ry
- Thank you received: 91
21 Jun 2025 07:18 #330621
by dm17ry
Replied by dm17ry on topic Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
that missing C9 is fitted with 1F/5.5V supercap on OSA104/OSA105 (absolute) encoders to keep them running for a while when the cable is disconnected. OSE do not need it
21 Jun 2025 07:37 #330622
I'll leave that up to you.
- jochen91
21 Jun 2025 08:28 #330624
by jochen91
It wasn't missing it was dryed out during the years and pulled down the battery voltage. Thats the reason the servo amp always complained position lost. I reordered the cap already but you know how it is: Nothing is as permanent as a temporary solution
- jochen91
19 Jul 2025 14:28 - 19 Jul 2025 14:55 #332016
by jochen91
Update:
So i took the machine mostly apart.
It is really dirty. I don't know what the pre-owners did with it, but dried up coolant is basically everywhere. Its yukky. It takes a lot of time to clean everything.
Linear guide rails on the Z Axis -> Scrap ( 2 out of 5 blocks are wiggling in the Rail) The rail is some special THK rail and is only sold as a set by Mazak. I requested a counter offer from a THK dealer... even more expensive.
The Y axis box ways are done. The lubrication system malfunctioned and the way wipers failed over the years. Already brought it in for regrinding. After that it needs to be scraped, which i am able to do. I lack a lot of experience in scrapping but its a "simple" box way and no dove tail ways.
Same goes basically for the X axis. Lube system got plugged up by failing way wipers and even the hardened ways got damaged. -> Regrinding.
Ballscrews:
Z Axis ballscrew is in good condition, but has no preload anymore.
X Axis ballscrew is in good condition, and still has preload.
Y Axis ballscrew feels a little bit crunchy... the balls need the be replaced and checked again.
Milling spindle:
The taper is shot and needs to be reground. I assume the bearings are also in no good condition. This repair also needs the be done professionally.
The good news:
I fixed my temporary encoder capacitor solution with a proper super cap. I even upgraded it to a 1.5F
Ballscrews:
Milling spindle:
The good news:
Last edit: 19 Jul 2025 14:55 by jochen91.
- jochen91
19 Jul 2025 14:43 #332019
by jochen91
- jochen91
19 Jul 2025 14:45 #332020
by jochen91
Time to create page: 0.142 seconds
