Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
27 Jun 2026 04:03 #347360 by Becksvill
just want to say that i am following closely on this as i am thinking of doing the same retro in the coming years on a mill turn like the intergrex. very interesting. i have 7 big cnc machines all 5ton plus machines running in my machine shop and love it. pretty keen to get into mill turn at some stage but don't really want to use the old controllers. they keep dying and i seem to have so much more machine once its got linuxcnc on it. but a mill turn is a big job!
if you want to swap notes on messenger or something hit me up probably best from my website beckcnc.co.nz.
i would love to chat this looks awesome
cheers
14 Aug 2026 10:03 #348727 by jochen91
Good day,
So i would like to do a status update. I'm nearly finished with the geometry overhall.
Z Axis is complete
Y Axis is complete (But the Ballscrew is rough. Maybe it gets replaced later)
X Axis is in the process of scraping and aligning.
Sand blasted and painted a lot of parts
Cleaned the machine even more (but still a mess, just less ;)
Spindel is still in progress.
The KM63 interface is fixed with new bearing and preload adjusted. But the clamping discs that clamp the spindle for turning/broaching is bend and needs to be reground. For now i will use it as it is to get the machine into alignment and if everything works with the original Maztrol i will start the conversion to LCNC and fix the rest of the spindle.
For now the progress wont be as fast as it used to be, because my son was born recently.
14 Aug 2026 10:27 - 14 Aug 2026 10:27 #348729 by jochen91
Last edit: 14 Aug 2026 10:27 by jochen91.
14 Aug 2026 10:31 #348730 by jochen91
14 Aug 2026 10:32 - 14 Aug 2026 10:33 #348731 by jochen91
Last edit: 14 Aug 2026 10:33 by jochen91.
The following user(s) said Thank You: meister, Aciera
14 Aug 2026 10:52 #348732 by Aciera
Well, congratulations!
Thanks for the update, looks like you are doing a proper job. That is quite a project you have taken on there.
The following user(s) said Thank You: jochen91
14 Aug 2026 11:44 #348734 by jochen91
Thank you!
It's true its my biggest project so far and in the beginning it was tremendous and overwhelmingly big. But with time and money i got an overview of the whole machine and all the things that need to be done. In retrospect thats how it always was when i started a new project. First my 3/4 axis mill, then the lathe and now the big mill turn. I like a challenge and i'm not afraid of making mistakes. They are a good teacher.
I learned so much in therms of scraping/painting/adjusting/planing. Its quit a lot of fun.
But to be honest i would not be so motivated to do this project without the help i recieved from you. So thanks to you as well!
Also my girlfriend helped and supported me a lot with lots of understanding and also alot of physical help.
14 Aug 2026 11:47 #348735 by jochen91
14 Aug 2026 11:51 #348736 by jochen91
16 Aug 2026 07:54 #348785 by Becksvill
man this looks just like my place in NZ you get the machine bug and it bites hard aye lol. and then its more and more machines until its hard to stop
Time to create page: 0.875 seconds
