- Thank you received: 9
Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
- new2linux
9 years 6 months ago #91515
by new2linux
Replied by new2linux on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Many thanks for all the help!
After tuning both axes, and watching the hal scope, I see changes when "P," is changed, not so noticeable are "FF1 or FF2". The one thing most noticeable is oscillation, especially at higher than 20"/min jog, especially at end or stop of jog, not so noticeable at slower feeds. This oscillation is something that I did not see when powered with old amps, should I re-think the (AMC) amp set-up? Could live with slower feed(up to 5"/min), will try to zero in on the preferred settings to best fit this vs. the full jog speed of 60"/min. The max "P" I used was 5000, this did not make servo vibrate, should I go higher? Tried the FF1 from .01 to .5; Deadband .00001; FF2 .001 or lower(ref to FF1).
Many thanks to all that make this forum possible, your suggestions warmly welcomed.
9 years 6 months ago #91518
Replied by andypugh on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
Why are you only tuning P and FF?
- new2linux
9 years 6 months ago #91534
by new2linux
thanks andypugh!
Well there is Deadband that is tweaked as well as P and FF1 & FF2. The speed of the feed effects the out come the most it seems. What are you suggesting?
many thanks!!
many thanks!!
9 years 6 months ago #91536
Well, normally when tuning a PID controller I adjust P, I and D.
- new2linux
9 years 6 months ago #91537
by new2linux
thanks andypugh,
Is there a target value for the I & D, or just trial and error? Will work that in tomorrow.
Many thanks!
Many thanks!
- Thank you received: 1480
9 years 6 months ago #91539
Replied by Todd Zuercher on topic Prototrak Plus Retrofit with Mesa 7i77 & 5i25 cards
The target value is what ever works with your hardware, and configuration. There are too many variables to say x value should with work with y setup. That is why it is called "tuning" a servo. (it is a lot like tuning a musical instrument.)
Time to create page: 1.868 seconds
