Retrofitting a 1986 Maho MH400E
8 years 10 months ago #102679 by RotarySMP
Thanks Andy. That has the first axis tuned and homing reliably. 2 more to go.
Mark
8 years 10 months ago - 8 years 10 months ago #103065 by RotarySMP
I switched cables to use the X axis's EXE to read out the Y axis glass scale encoder. That worked, so I was able to confirm that the encoder is fine. I also got the axis tuned and homing. Next, will need to use the oscilloscope to compare the signal at the EXE output with the signal input to the MESA and the HALoscilloscope, to see whether the Y axis EXE is faulty , or if the wiring is noisy.
I've noticed two other issues...
When I start LinuxCNC, I get this error message...
I can click it away. The machine starts in physical E-Stop, so I have push the start button to get it out. What setting do I need to set in the HAL or INI so that this message doesn't appear at LinuxCNC start?
The second issue is that there is garbage written into the tool area...
I thought it was some corrupt data in the tool table (which I haven't set up yet), but that is still empty. Any suggestions what is causing this?
Mark
Last edit: 8 years 10 months ago by RotarySMP.
8 years 10 months ago #103110 by bevins
Replied by bevins on topic Retrofitting a 1986 Maho MH400E
Mark
Upgrade your gmoccapy. that was a bug a while ago if I remember correctly that has since been fixed. When I start a new system with the live CD I have that also.
8 years 10 months ago #103111 by RotarySMP
Thanks. Will do.
Mark
8 years 10 months ago #103135 by RotarySMP
Does anyone have a good tip as to which AMP connector model or series this is?
I have searched the TE.com connector search function, Digikey and Mauser, and couldn't identify it.
It is 2x6, 1/10"(2.54mm) pitch (or maybe 2.5mm).
This is the Heidenhain EXE board output connector. If I can track down some 5x2 twisted pair, double shielded cable, I'd like to rewire the EXE outout to utilise the differntial signals.
Mark
8 years 10 months ago #103137 by andypugh
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
If the pins are at 2.54 pitch then I think that almost anything for PCB headers will work but maybe not lock.
This looks like the one you want:
www.digikey.com/products/en?mpart=925370-6&v=17
(Don't forget that you will also need the terminals and the correct crimping tool)
Moderators: piasdom
Time to create page: 0.334 seconds
