- Thank you received: 595
Retrofitting a 1986 Maho MH400E
- RotarySMP
8 years 4 months ago #111660
by RotarySMP
Sorry, my mistake, I confused the 7A1 relay with the SH1 start switch in my last post. I wired the second pole of the SH1 start switch to V.Button.0.
Mark
Mark
The following user(s) said Thank You: drimaropoylos
- drimaropoylos
- Thank you received: 40
8 years 4 months ago #111664
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
The way I like the machine to operate is this
1 close the K1 and wait for linux-gmoccapy to boot
2 press off all the estop boutons, doing so the power bouton on the gmoccapy from grayed becomes ready
3 press the double hard bouton next to soft power bouton and the machine starts, oiler-indramat… ext (and the power bouton goes green)
4 if I press again power bouton (hard or soft) the machine will power off
If something is not ok, as soon I let go the bouton everything goes off (not estop)
If something goes wrong in wiring the machine will power off , if something goes wrong to software everything powers off (not in estop but in power off)
I don’t know if this the proper behavior of a cnc machine, I haven’t use cnc in the past
- drimaropoylos
8 years 4 months ago #111665
by drimaropoylos
I don’t think you make something wrong, I simply prefer that behavior of the machine
- drimaropoylos
8 years 4 months ago - 8 years 4 months ago #111724
by drimaropoylos
I will use the MAHO 28X2-4 pin from relay board to feed motion.enable pin on linuxcnc so the controller knows if something went wrong.RotarySMP wrote: You need the LinuxCNC Estop signal connected through your MESA card to the the MAHO 28X2-4 pin on the I/O board so that the Mill will E-Stop automatically if LinuxCNC senses an internal software screw up.
Last edit: 8 years 4 months ago by drimaropoylos.
- drimaropoylos
8 years 4 months ago #111725
by drimaropoylos
In you approach is that when everything is power off gmocapy will show emergency off even if all the emergency boutons are on, when you press estop everything is power up except the servos, in this state gmoccapy will show emergency bouton on and power bouton off, and then when you press the power bouton servos goes on and gmoccapy show power on.
In my approach I have described what happens in previous post.
Is there a standard (or mainstream approach) to describe what is the proper behavior of a machine to the estop and power boutons.
- drimaropoylos
8 years 4 months ago #111758
by drimaropoylos
Moderators: piasdom
Time to create page: 0.236 seconds
