Retrofitting a 1986 Maho MH400E
8 years 5 months ago - 8 years 5 months ago #110284 by PCW
Replied by PCW on topic Retrofitting a 1986 Maho MH400E
On a multiplexed kb system there is a matrix of outputs and inputs
so for example a 64 key matrix could have 8 outputs and 8 inputs
with the key switches at the intersections. Typically the 8 outputs are driven
one at a time and the 8 inputs read every time a different output is energized
Last edit: 8 years 5 months ago by PCW.
The following user(s) said Thank You: drimaropoylos
8 years 5 months ago #110286 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Again, thank you for the response.
8 years 5 months ago #110304 by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
"I decided not to get a 7i83, as I have enough spare inputs on the 7i77" Oh No ! :ohmy: What about the Tool changer ? What about the electronic tool probe/part probe ? What about the "A" and "B" axis? What about the Blinking Lights if the machine chokes on a job ?:laugh:
John --- I bet Mark is just showing us a bare bones proof of concept conversion and holding back what is really going on--:silly:
8 years 5 months ago #110310 by drimaropoylos
Lol
8 years 5 months ago #110312 by RotarySMP
LMAO!!! MAHO made some real Rube Goldberg style mechanisms for tool changing didn't they.
A fourth or fifth axis shouldn't need much I/O, if you connect an analog motor driver and encoder to one of the six analog control loops, and then should only need an input pin for an index.
A tool probe is also only a single input pin. I was intending to have a connector on the pendant, and plug a probe into it.
John,
My plan of the MatrixKB in this post...
forum.linuxcnc.org/12-milling/33035-retr...00e?start=310#103928
I finally got the last buttons printed, and could assemble the lower button carriers. Then continued with the button wiring. I'd forgotten how time intensive wiring is.
Sorry about the photo rotation. I rotated this when I cropped it, and all the windows programs show it with the correct orientation, but it the orientation seems to be ignored by the forum software.
Mark
8 years 5 months ago #110964 by drimaropoylos
Moderators: piasdom
Time to create page: 3.137 seconds
