- Thank you received: 40
Retrofitting a 1986 Maho MH400E
- drimaropoylos
8 years 4 months ago - 8 years 4 months ago #111512
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
We have a little problem with the e-stop double bouton. Gmoccapy activates only after we release the bouton, so the 24 volt from the Mesa to 209 joint to activate the 19K1 is not going to be present when we press the 3SH1 bouton (the second bouton contact).
Last edit: 8 years 4 months ago by drimaropoylos.
- drimaropoylos
8 years 4 months ago #111574
by drimaropoylos
- drimaropoylos
8 years 4 months ago - 8 years 4 months ago #111578
by drimaropoylos
Never mind, I was wrong, the boutons pin of gmoccapy have different behavior than soft boutons on screen. They activate gmoccapy as soon you press then and not after release them.
- RotarySMP
- Thank you received: 595
8 years 4 months ago #111589
by RotarySMP
Hi John,
Interesting observation. I hadn't notice that behavior. For testing I have the Physical start button from the the MAHO connected to close the EStop through one set of poles, and to signal V.button.0 through it's second poles. While pushing and holding that, I have been clicking the on screen V.button 1, and it has latched fine.
Mark
drimaropoylos wrote: Never mind, I was wrong, the boutons pin of gmoccapy have different behavior than soft boutons on screen. They activate gmoccapy as soon you press then and not after release them.
Hi John,
Mark
- drimaropoylos
8 years 4 months ago #111594
by drimaropoylos
It should latch even without V.button 1, I thing.
- RotarySMP
8 years 4 months ago #111614
by RotarySMP
You could set it up like that, but since all the LinuxCNC interfaces are set up for a separation between "E-Stop close" and "Machine Start" I decided to implement it that way needing both to be pushed similataneously.
Mark
Mark
Moderators: piasdom
Time to create page: 0.812 seconds
