- Thank you received: 595
Retrofitting a 1986 Maho MH400E
- RotarySMP
The controller that I intend to put in has no way to communicate with the existing servodrives, it has no analog output. It has analog output only for spindle control. That is why I have to replace everything.
If you haven't bought it yet, then dont use that controller. It is a big job and a huge waste of time and money to rip out the driver and motors if they are working fine and were designed to match the inertia of the MAHO's axis. Just get a MESA 7i77 and you have the analog outputs needed. This is a LinuxCNC format, so the expectation is that you are planning a LinuxCNC retrofit. If not, then you would be better off starting a thread in the Newkye support forum.
RotarySMPT I agree, but I'm new here, I do not know how to do it. If there is moderation here I would ask if they could do this from a post of mine, for example. I did not want to disturb your sharing or your work with myself ...
I like all things MAHO, but when I went searching the internet for info on my ones problems, I found it frustrating to have to search for relavant information buried in threads about other machines. John's 600E seems very similar to my 400E from the control prespective, but I am sure there are other people with MAHO MH300C's confronted with similar problems to you, who would appreciate the good suggestions you received here, but who won't find it here as it is no buried so deep in this thread.
There is a button to start a "New Topic"...
Mark
- db1981
- Thank you received: 276
no seminar, break at the initial operation from an production line....
You can left the manual part disconnect, the MH700 had this buttons on the control Panel.
- RotarySMP
How come these lines were commented out?
//pin in unsigned POSITION_COUNT;
//variable transm_pos pos[POSITION_COUNT];
//#define SWITCH_LEFT 0
//#define SWITCH_RIGHT 1
//#define SWITCH_CENTER 2
- RotarySMP
- drimaropoylos
- Thank you received: 40
Nice work on the panel Mark, are you going to use 7i73 for the matrix on the panel?
- drimaropoylos
