Retrofitting a 1986 Maho MH400E
8 years 1 week ago #119239 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Hello, thank you for the info, so in newer models the shaft for the encoder is like this?
8 years 1 week ago #119240 by drimaropoylos
I also was thinking to put a hallow encoder directly in the shaft, but I am afraid the oil mist will find its way insight the encoder.
8 years 1 week ago #119241 by RotarySMP
Hi John,
That encoder looks like a great solution (for my lathe project :)), at least for shafts which are not within an oil bath, Strange they used -Z bearing shields instead of -2RS seals.
Where did you source it from?
Mark
8 years 1 week ago - 8 years 1 week ago #119242 by drimaropoylos
They are very common encoder in elevators, so they are relative cheap.
www.aliexpress.com/item/Good-quality-GHH...5e-acf2-3d73ec1c44a1
.They can even customize the bore.
Last edit: 8 years 1 week ago by drimaropoylos.
8 years 1 week ago #119249 by RotarySMP
Thanks for the link. I should have guessed.
8 years 1 week ago - 8 years 1 week ago #119382 by RotarySMP
Yesterday I pulled finger and did a little more wiring. This is the connector for the two encoders which do feed override and rapid select.
The Heidenhain 602D EXE I ordered arrived, so hopefully I can wire that up and get three axis motion at last.
Mark
Last edit: 8 years 1 week ago by RotarySMP.
Moderators: piasdom
Time to create page: 3.154 seconds
