- Thank you received: 18
Retrofitting a 1986 Maho MH400E
- Glemigobles
7 years 9 months ago #123773
by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Also Mark, I haven't the faintest clue on how to use a shaper but it's really cool you can do that setup! Prior to your mentioning it, I've never seen anybody use that attachment before.
7 years 9 months ago - 7 years 9 months ago #123774
They are often called a "slotting head" as they convert the mill to a slotter.
www.lathes.co.uk/rothley/
Typically used for keyways and splines.
There is a slotting head for my Harrison mill, but I let one escape on eBay last year and haven't seen another since.
But I have been giving seriois consideration to making my own from scratch, with the added feature of a CNC rotation for the cutter.
This would allow for the generation of internal gears like this:
However I don't think that there is any need for the 5th axis, circular interpolation ought to work just fine.
I think that to re face that anvil I would have used the lathe and 4-jaw chuck, though.
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
Glemigobles wrote: Also Mark, I haven't the faintest clue on how to use a shaper but it's really cool you can do that setup! Prior to your mentioning it, I've never seen anybody use that attachment before.
Last edit: 7 years 9 months ago by andypugh.
The following user(s) said Thank You: J Green
- RotarySMP
- Thank you received: 595
7 years 9 months ago #123776
by RotarySMP
With the pruchase of my Maho I received the user manual and some Phillips 432 programming guide. When that slotting head came up for sale, I contacted DMG to ask if it fit my machine (it was advertised as a 400P accessory), and they sent me their part machining drawing of the adaptor flange so I could compare dimensions. I was suprised they would hand out such a drawing. It doesn't have the casting pattern information, but contains all the dimensional and tolerancing information.
At some point I also got a near complete set of assembly drawings for the 400E from someone on the internet. As they have some Cryllic annotation on them, I am assuming that import requirements for some eastern states required a set of assembly drawings with delivery. Those drawings have no dimensions, and I do not have the associated parts lists to cross reference parts on drawings to actual MAHO part numbers.
I have not seen a parts catalog with exploded views from MAHO like in that Rockwell video.
The wiring diagram set from MAHO is really the only thing you need for a linuxCNC conversion. The first couple of pages lists the electrical components.
My lathe is a Boley 4LV. so it is pretty small.
madmodder.net/index.php/topic,7884.msg147233.html#msg147233
I have a nice Bison 4 jaw independant chuck, but at 125mm, it is not large enough to have an adequate through hole to grip that anvil on the larger step. The protusion would have been excessive, and the tapered edges do not lend themselves to a solid grip. Using the 100mm insert face mill in the horizontal spindle was my first plan, but was suprised how much I would have to pack it up off the table to reach it from the top of Z travel. I may still have to do that, depending on hard spots in the anvil face.
Another option would be to mount the anvil to the lathe cross slide, and a fly cutting bit in on a disc in the chuck and fly cut it that way.
Mark
Mark
The following user(s) said Thank You: Glemigobles
- RotarySMP
7 years 9 months ago #123777
by RotarySMP
Thanks. One thing about a retrofit forum is that the posting normally stops once the machine is running. I always found that kind of frustrating. You follow a thread and then it dries up and you wonder what the guy is using it for and how it is working out in practice. As long as the administrators here tolerate it, I'd like to keep posting my experience using the machine, set ups, accessories, modifications, changes to my retrofit etc.
I still have a fair bit to do on it:
- My user control module really needs the pendant.
- We are going to redify the gearbox comp program to give it full control of the spindle. We'll send LinuxCNC start/stop requests to the comp rather than the other way around.
- I want to make a tool length setter and a 3D touch probe
- Andys engraving code is making the fourth axis itch burn.
- The dolly still needs to be made and the machine moved.
- Since I got the horizontal spindle's overarm, I guess I should keep an eye out for a 40 taper mandrel and some horizontal cutters.
- I need to set up the tool table.
- I have a fog buster which I was planning to install, but the flood coolant works so well, I might pt it on the lathe.
Mark
Mark
- J Green
- Thank you received: 24
7 years 9 months ago #123798
by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Saw this in a 1982 product range brochure . Hope it doesn't cause undue lust for old Maho attachments. Note item #7 -- their high speed spindle , but how high a speed it was is not noted. there is a reference to a accessory brochure having more information. Hope you find that accessory brochure in your Maho journey .
- J Green
7 years 9 months ago - 7 years 9 months ago #123802
by J Green
Glemigobles The Maho manuals I have seen -- parts list & machine part illustrations , were broken up into sections of different areas on the machine. They seemed (to me ) very hard to read and hard to understand. Marks illustration of the Maho spindle is a example of what I am referring to.. The parts listings also used many German words-- I have trouble with the English language ( born and raised in the USA ). :laugh:
You-ens on the East side of the Atlantic ocean usually have better command of the English language than me. My thought about buying a parts list /part illustration is that it sure would be worth seeing what is being offered or a right to return for a refund.
There is a French hobby web site that has some / many / quite a lot of information --- maybe someone can note it's web address !
Hope when retrofitting your machine there is as much information shared here as Mark has/is doing.
Last edit: 7 years 9 months ago by J Green.
Moderators: piasdom
Time to create page: 1.046 seconds
