Retrofitting a 1986 Maho MH400E
7 years 9 months ago #124144 by tommylight
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
RotarySMP wrote: But I still have the 6V lead acid batterys removed from the MAHO, so I'll throw them on a charger and see if they have any life still in them, and add a dropping resister to get 5V.
Mark
You can use 4 NiMh batteries as they will give exactly 5V (1.25V each), and they are cheap and rechargeable. I would not recommend recharging them while in use as they require 1.4V each for charging, getting to 5.6V total.
Do not use resistors for voltage regulation on dynamic loads, use 2 diodes in series, it will give a 1.2V voltage drop and be stable enough for what you need.
The following user(s) said Thank You: J Green
7 years 9 months ago - 7 years 9 months ago #124145 by RotarySMP
Thanks for that. I have NiMH AA's. I think I have nominally 800 mAh ones, so they should work for up to an hour.
Cool, I can 3D print the holder:
www.thingiverse.com/thing:456900/files
Last edit: 7 years 9 months ago by RotarySMP.
7 years 9 months ago #124151 by tommylight
Nice holders, i need to finish a 3d printer i started several years ago !
7 years 9 months ago #124156 by RotarySMP
You should. They are very helpful.
Mark
7 years 9 months ago #124160 by tommylight
At the time i could not think of anything useful to make with it ! Still don't, but i would like to have it finished.
7 years 9 months ago #124166 by RotarySMP
I am not a big fan of plastic stuff, but once you have a 3D printer, you would be suprised at the problems which pop up which it can solve.
Moderators: piasdom
Time to create page: 1.302 seconds
