- Thank you received: 595
Retrofitting a 1986 Maho MH400E
- RotarySMP
7 years 7 months ago #127895
by RotarySMP
Thanks for that Andy. Where do we find those new pin names? Any Idea when 2.8 will be released?
Mark
Mark
7 years 7 months ago #127898
The release manager has gone rather quiet....
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
linuxcnc.org/docs/devel/html/man/man9/motion.9.htmlRotarySMP wrote: Thanks for that Andy. Where do we find those new pin names?
No idea. I was hoping that it would be around last new-year.Any Idea when 2.8 will be released?
- RotarySMP
7 years 7 months ago #128180
by RotarySMP
This is the first tool path I have generated with CAM.
As you can see I screwed up the tool material setting, and number of flutes, and left it as 2 flute HSS, when it was an 8mm carbide four flute, explaining the 1/4 feedrate it should have had.
I used a FANUC 11m PP to generate the code. Then edited it on a PC in wordpad to delete some of the initial codes which LinuxCNC doesn't have (G23?), and also edited the code in mousepad. It ran fine, but the code part of the window only shows a line one, the rest is blank.
I have attached the gcode file. I would appreciate if anyone could please point out what LinuxCNC is being tripped up on.
- hanmon
- Thank you received: 23
7 years 7 months ago #128184
by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
Hi Mark,
my first gues, the comment probably?
I can try to run the code on my machine tomorrow.
- RotarySMP
7 years 7 months ago #128208
by RotarySMP
Thanks Hanno, I did delete that G01 from the header, as LinuxCNC doesn't like a G01 without an F.
Mark
Mark
- RotarySMP
7 years 7 months ago #128271
by RotarySMP
This time I hand coded this tool path, as I wanted to get a better feel for spiral paths. The feed rate is the correct 700mm/min for the 8mm 4 flute carbide this time.
Mark
Mark
Time to create page: 5.094 seconds
