- Thank you received: 18
Retrofitting a 1986 Maho MH400E
- Glemigobles
7 years 7 months ago #128535
by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Thanks a lot for all the info guys, I will definitely work on becoming a bit less clueless when I get some time to read all the manuals. In the meantime it's great to know what cables and accessories are needed, I can order them online to have everything ready. Will it be possible to connect both the Maho's main spindle drive and my small VFD auxiliary spindle using the cards I got?
- Thank you received: 7491
7 years 7 months ago #128555
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
I do think it is possible, granted you do not need all 5 servo outputs from the 7i77. You can use any of the +-10V outputs and corresponding encoder input to have a closed loop VFD spindle control, but most probably you will need to use the ABS component and wire an output for the VFD in HAL to have it reverse the spindle, as the VFD does not like the negative voltages that 7i77 outputs for servo drives when reversing..Glemigobles wrote: Will it be possible to connect both the Maho's main spindle drive and my small VFD auxiliary spindle using the cards I got?
The following user(s) said Thank You: Glemigobles
- RotarySMP
- Thank you received: 595
7 years 7 months ago - 7 years 7 months ago #128558
by RotarySMP
Is your MAHO an E model or an E2? If it is an E model, then the spindle control it just the pins which switch the various gearbox and on off relays, and the comp which works out when to switch them.
Does your HF spindle have a tool changer, or at least tool release, or is it just one of the ER collet spindles? To completely integrate both spindles under inuxCNC control will require you to write a comp, and provide LinuxCNC with feedback as which spindle is fitted. However if it is an ER collet HF Spindle, where tool changing is slow anyway, you could simple switch it on and off manually and use tool paths which dont include splindle control.
Mark
Mark
Last edit: 7 years 7 months ago by RotarySMP.
- Glemigobles
7 years 7 months ago #128564
by Glemigobles
My Maho is an E model just like yours. The HF spindle is the ER collet type. I was curious about the possibility of setting it up in LinuxCNC because switching it on and off manually is a drag, and setting the frequency using the knob on the VFD sometimes gives poor results.
For exmaple, I cut acrylic at 244 Hz to match the spindle with the maximum feed of the Maho (1500), but the knob seems to "click" at uneven numbers and getting it to stay at 244 instead of intermittently oscillating between 244 and 243/245 is tricky to say the least. It would seem that shouldn't be a big deal, but it sometimes has the effect of getting extruded acrylic to stick to the cutter.
The VFD goes from 120-300 Hz and the spindle goes from 6000-18000 rpm. So 1 Hz is a difference of 66,6 rpm. Cast acrylic doesn't seem to care, but the extruded variety is very sensitive to temperature and you need the feeds and speeds to be just right or you risk breaking the tool (plastic builds up on the cutter and forms a solid blob which eventually causes the carbide to break when the tool enters the workpiece; this can happen very quickly when you're not paying attention, which I usually don't since I work while the machine is on).
- RotarySMP
7 years 7 months ago - 7 years 7 months ago #128714
by RotarySMP
LinuxCNC can definitely do what you want, it can do basically anything
Does the MAHO vertical spindle remain installed, and the HF spindle attach next to it, with both usable, or do you remove one and install the other? Does the HF Spindle mount with the same axis center as the MAHO (could simplify the need to have different tool offset tables)?
In hardware, assuming you remove the MAHO spindle to attach the HF one, you will have two parallel systems, sharing no components. You will have a set of I/O pins dedicated to the VFD on/off/direction/speed feedback etc, just as you have pins dedicated to the MAHO on/off/direction/and gearbox control/spindle at speed etc.
In software, there is a comp for controlling a VFD, and a comp for controlling the MAHO gearbox. What you will need is a software widget to choose which one is currently active, and therefore which one gets to parse S words, and spindle commands , which input pins are read, and which output pins are written.
If you look at the schematic of how Sergey's gearbox.comp is controlling speed..
github.com/jin-eld/mh400e-linuxcnc/blob/...e%20flow%20chart.odg
... you need to start above that with a first question, "which spindle is currently fitted", and if it is the VFD, branch off into a parallel flow of VFD control decisions.
Ideally you could fit a switch, which automatically closes when the HF spindle is installed, and that switch feeds the spindle selection widget. So if the MAHO head is fitted, that pin is read and, the maho gearbox.comp parses the S words. If the HF head is fitted, then you have your S word parsed by the VFD.comp.
I am not enough of a software guy to know whether it is best, or even possible to have three comp's (A spindle selector widget, the gearbox comp, and the VFD.comp), or whether you will need to merge those three into one new comp. The advantage is that this is open source stuff, so you shouldn't need to recreate all code.
Having the VFD speed command generated by LinuxCNC digitally, rather than trying to set a specific frequency from a Pot should meean you hit that exact frequency every time.
Mark
Mark
- RotarySMP
7 years 7 months ago - 7 years 7 months ago #128761
by RotarySMP
I had another play with thread milling today.
Also needed a couple of round pieces of 6mm mild steel plate.These are the end plates for the wheel of my sand muller. The Maho made pretty quick work of chopping out the circles. At least least it seemed faster while cutting at 700mm/min, and required no effort from me other than chopping out the last half mm with a cold chisel before turning the back side.
Mark
Mark
Time to create page: 0.880 seconds
